Thread: which block is better
Results 1 to 5 of 5
  1. #1 which block is better
    GT Level Member undecided's Avatar
    taylors falls MN
    on a turbo set up would the l36/l26 be better than the l67/l32?
    im wanting to make an overall fast and powerful turbo grand prix
    but not sacrifice too much reliability.
    i read the thread about top swaps already so i know the power advantage
    but which lasts longer under boost?
    1998 white grand prix gtp - speed daddy headers & ported supercharger
    1982 z28 Camaro - all original with only 80k miles and rust free - slow as heck
  2. #2 Re: which block is better
    Apr 2009
    stockton ca
    higher compression equals more power more power equalls more beating on it if you build it right and dont neglect it doesnt matter
  3. #3 Re: which block is better
    a higher compression block will have better out of boost driveability while the low compression block will take the boost better. because of turbos love of running high boost levels, usually a turbo setup is best on a low compression block. high compression is best left with an m90 build since you dont normally run anything more than about 12 pounds of boost.
  4. #4 Re: which block is better
    Apr 2009
    stockton ca
    or what he said im drinkin and cant be held liable for my opinions
  5. #5 Re: which block is better
    taylors falls MN
    lol at torque
    and thanks a ton bio
  1. n/a block vs l67 block
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 02:38 PM
  2. New kid on the block
    By padlock470 in forum Introductions/Noob Questions
    Last Post: 12-23-2008, 04:05 PM
  3. New guy on the block
    By Milestone in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:17 AM
