Thread: PVC Valve ??
Results 1 to 10 of 10
  1. #1 PVC Valve ??
    SE Level Member TurboGTP's Avatar
    Cali
    I have searched by didn't find anything on how to plug the Pvc Valve on the L26 Upper intake Manifold.
    If you have a How-To that would be great. Pics would be a plus
    Show Me The Boost
  2. #2 Re: PVC Valve ??
    Cali
    Any One ??
    Show Me The Boost
  3. #3 Re: PVC Valve ??
    Charles City, IA
    Its under the map sensor.
    SMGPFC Two Nipple General
  4. #4 Re: PVC Valve ??
    Cali
    So all i have to do is remove the Spring & Valve... then plug the bottom hole right.
    Show Me The Boost
  5. #5 Re: PVC Valve ??
  6. #6 Re: PVC Valve ??
    Cali
    why are you plugging it?
    Because i'm going to run a Valve cover breather
    Show Me The Boost
  7. #7 Re: PVC Valve ??
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    I still run my PCV valve on mine. No reason to remove it.
    Retired
    Turbo'd
  8. #8 Re: PVC Valve ??
    Cali
    Quote Originally Posted by VictorSmalls View Post
    I've read on some threads that people block it & on others that they don't .
    So yours is not pluged & you have a valve cover breather also or ?
    Show Me The Boost
  9. #9 Re: PVC Valve ??
    Dec 2008
    Tyrone, PA
    Quote Originally Posted by TurboGTP View Post
    I have the PCV and also run the breather on the valve cover.
    Retired
    Turbo'd
  10. #10 Re: PVC Valve ??
    Cali
    Thanx for the info. I will run a PVC then & see how it does
    Show Me The Boost
  1. EGR valve
    By cobra8432 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:12 PM
  2. PCV Valve
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2010, 03:14 PM
  3. Pcv valve
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2010, 12:16 PM
  4. EGR Valve! What does it do?
    By Bruty74 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2009, 09:40 PM
  5. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
