is this the first time its done it? do you have a scan of the run?
If you have hptuners send the file to chris_8907@yahoo.com and ill look at it.
You have a electronic throttle body right? there is a table the pcm looks at as a rationality check incase the electronic throttle body screws up. keeps you from accelerating when your foot is off the pedal. if you exceed the airflow values in this table it will trigger a limp mode. might zero this table out for the time being to check things out but dont leave it zeroed out!!!
