Thread: Wideband
Results 1 to 18 of 18
  1. #1 Wideband
    SE Level Member TurboGTP's Avatar
    Cali
    What is a good Wideband to get for my car ? I will be going turbo so i need to get one. Any info would be good Thanx
    Show Me The Boost
  2. #2 Re: Wideband
    i always liked the AEM setup because it came with a gauge.
  3. #3 Re: Wideband
    Cali
    Do you know which one or part number ?
    Show Me The Boost
  4. #4 Re: Wideband
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Wideband
    SE Level Member Spockssilver02's Avatar
    Aug 2008
    Kennesaw, GA
    I've been very happy with the NGK unit. It seems to get good reviews for accuracy. It comes with a Bosch O2 sensor, although you can upgrade to an NGK O2 sensor.
    Home » Shop » Wideband O2 » O2 Controller » NGK Powerdex AFX - Air Fuel Ratio Monitor Kit - Wideband O2 - PN 91101 - w/ Standard Sensor
    02 Silver GTP - 3.3 MPS, XP, 105s, Ported Gen 3 & LIM, Wizaired CAI, TOGs, N*, LQ4 MAF, PRJ Wires, 180 stat, AL 104s, GMPP handling kit, AGX, Eibach, HPT, NGK WB
  6. #6 Re: Wideband
    Cali
    Thanx for that info guys.. The Innovate Wideband looks pretty good, I might get that 1.
    Show Me The Boost
  7. #7 Re: Wideband
    Banned - Busted For Scamming
    Feb 2009
    You can get the aem for the same price buy it now on ebay.
  8. #8 Re: Wideband
    Cali
    Quote Originally Posted by TurboGTP View Post
    Which one do you guys think is better ?
    Please wait
    Image not available
    Show Me The Boost
  9. #9 Re: Wideband
    Charles City, IA
    I have the NGK AFX
    SMGPFC Two Nipple General
  10. #10 Re: Wideband
    Cali
    I have the NGK AFX
    Are you happy with it ? Does it work good, any problems with it ?
    Show Me The Boost
  11. #11 Re: Wideband
    I have the NGK AFX
    x2. is what im using right now
  12. #12 Re: Wideband
    they all work the same, get the one you like how it looks and know you can mount it somewhere you want it.
  13. #13 Re: Wideband
    Charles City, IA
    I pulled out my ash try and have mine down there.
  14. #14 Re: Wideband
    Charles City, IA
    Works fine. I have had no problems with it. I am recording from it threw my egr wiring.
  15. #15 Re: Wideband
    Cali
    Oh ok thanx for the info.
    Show Me The Boost
  16. #16 Re: Wideband
    Jan 1970
    Maquoketa, Iowa
    I have the PLX M-400 mounted in front of the speedo on the steering wheel. I like the AEM's also, we put one in a regal, easy install.
  17. #17 Re: Wideband
    SE Level Member BlackGS's Avatar
    Central Jersey
    What are you using to scan/tune? I have the PLX SM-AFR which integrates easily with HP Tuners.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  18. #18 Re: Wideband
    Cali
    Quote Originally Posted by BlackGS View Post
    I don't have no scaner & i'm not going to tune my car. Some guy is going to Tune it for me that Tunes GM Cars
    Show Me The Boost
  1. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
  2. Anyone run an LC1 Wideband...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 03-24-2008, 09:41 PM
