since being new to the turbo side, i was wondering if there are any maintenance to be done/checked on the turbo or any of the other parts of the turbo setup, sic as BOV, WG, I/C, etc? like how the m90 needs its s/c oil to be changed every so often depending on how hard its being used as well as checking the conditions of the rotors and so forth.
also i have a catless straight pipe after the turbo downpipe. im using a 80/20 methyl alcohol to water mixture that sprays once i reach 10psi. the car shoots fireballs when letting off after going WOT above 10psi(remember alky sprays at 10psi+) good for the turbo? also my friend said while i was going WOT(at night) he said he saw blue flames coming from the exhaust. is this from the use of methyl/rich gases escaping?![]()
