Thread: Genral maintenance on my 98 GTP?
Results 1 to 14 of 14
  1. #1 Genral maintenance on my 98 GTP?
    SE Level Member hunter_alexander's Avatar
    Erie Pa.
    Ok, well with having problems on my GTP last night, I have begun to wonder more about a few things.
    This car has 117k miles on it. Bought it off the original owner who took great care of her.
    My questions are this,
    Timing chain and gears. When is a good time to replace them? Do they have the plastic teeth on them like other GM cars? I know mine is original.
    When should I worry about replacing the sensors, coil packs etc?
    Since this is my daily driver, and has run fantastic for me for almost a year now, I havent worried much. Been wrenching on my 87 Cutlass more. But now that I am starting to have some problems, my GTP has become my centerpoint of maintenance.
    Any guidance on it would be very helpful.
    thanks
    Craig
    If all else fails, throw money at it..... that'll fix it.
    Check out my website here: http://craig.beesky.com/1987_olds_cutlass.htm
  2. #2 Re: Genral maintenance on my 98 GTP?
    TDCRacing
    Guest
    As far as sensors ect......Replace them only when they go bad.
    Tell us the problems you are having or concerns that you may have and we will point you in the right direction...If you dont know how long it's been for plugs and wires I would recomend a set of new wires and also a set of autolite 605's wich will run about 10-12 bucks...For a dd i wouldnt run anything but ngk or autolites...If money is no option then sure there are better plugs out there but most use the 2 I mentioned above.
    If you have an ses light on then find out why that is and report back to us
  3. #3 Re: Genral maintenance on my 98 GTP?
    Bastard Reptile's Avatar
    Kansas City, MO
    Concerning the timing chain...I think that the tensioner is probably due to be replaced...there's not really any need to change the chains if you don't absolutely have to. The tensioner is a task in it's own, doing the chain adds complications to it.
    I'd do a fuel filter, plugs & wires, and change the trans fluid and filter. Pretty much it IMO.
  4. #4 Re: Genral maintenance on my 98 GTP?
    Barksdale AFB, LA
    Quote Originally Posted by hunter_alexander View Post
    It's all metal. The only plastic piece is the timing chain damper which will eventually wear out, though I've never heard of one failing in a high mileage car.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Genral maintenance on my 98 GTP?
    Erie Pa.
    Thanks guys. Thats what I needed to know.
    Good to hear that the timing chains are all steel. The Olds 307 and other engines came with a timing chain that had plastic gears for the cam gear. This would always loose teeth, get into the oil pickup and ruin the engine. Thats why I figured I would ask.
    I figured as much on the sensors, just curious.
    As far as the regular maintenance, I have done all that already, fuel filter, tranny etc.
    I was just curious as to the engine components and if there is a know fail point with them.
    Appreciate the info.
  6. #6 Re: Genral maintenance on my 98 GTP?
    TDCRacing
    Guest
    No problem man...hope you like the fourms....
  7. #7 Re: Genral maintenance on my 98 GTP?
    Barksdale AFB, LA
    The only recurring issue across the board for nearly all 3800 Series IIs is the intake manifold gaskets. They leak (mine were leaking by 45k miles).
  8. #8 Re: Genral maintenance on my 98 GTP?
    Erie Pa.
    Hell yeah. I am a member of various forums for my Cutlass and I find these places invaluable for help, research and overall data.
    Been a member here since march, which isnt long, but I have gotten a lot of info from here.
  9. #9 Re: Genral maintenance on my 98 GTP?
    SE Level Member beast3300's Avatar
    I have read in the Catco catalog that also lists O2 sensors on the W-bodies it said replacement interval 80,000 miles.
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  10. #10 Re: Genral maintenance on my 98 GTP?
    PA
    There is a bit of maintenance that I would recommend at this mileage:
    • Transmission fluid and filter - This is a big one in my book since the transmissions are one of the weakest points of the car. But if you take care of it and drive smart, it should last you awhile.
    • Lower intake manifold gaskets - Probably the second biggest problem spot. Anything over 70k miles and these should be replaced. They just plain suck.
    • Cooling system flush and coolant change - This fits right in when you do the LIM gaskets mentioned above.
    • Supercharger fluid - This needs to be changed every 30k miles or so. Only when the coupler starts making noise should that be changed.
    • Fuel Filter - Every 30k miles.
    • Plugs & Wires - Depends on what kind you have. But should be changed on a regular interval. I would say every 30-50k miles or so.
    • PCV Valve - Just cheap and easy to do every 30k or so.
    • O2 sensor - Just the front needs changed every 50k or so.
    As for timing chain or tensioner. I don't see a reason to tear it down that far to do. If it starts making noise from a wearing tensioner, then consider doing something. Until then, forget about it. Coil packs and other sensors only need changed when they are acting up, which isn't very often.
    Again, this is just my opinion, so take it for what it's worth....which is not much
    2001 GSE
  11. #11 Re: Genral maintenance on my 98 GTP?
    Erie Pa.
    Thanks. That is a great list.
    I thought that the sc 3800's didnt have that intake gasket problem. Thought it was only for the NA 38's.
    for the O2 sensor, why only the front one? By that I mean, there are two right? Why would only the front one go bad?
  12. #12 Re: Genral maintenance on my 98 GTP?
    Barksdale AFB, LA
    Both engines use the same gasket design.
    The one in front of the cat has nothing to protect it in case of a overly rich condition or coolant burning in the combustion chamber or any of a number of things. These things can foul a O2 sensor pretty quickly.
    The rear O2 sensor is sitting behind the cat (because its job is to monitor the cat's performance) so the cat takes care of a bunch of the nasty before it reaches the sensor.
  13. #13 Re: Genral maintenance on my 98 GTP?
    Erie Pa.
    Gotcha thanks.
  14. #14 Re: Genral maintenance on my 98 GTP?
    Erie Pa.
    Obviously I am still learning about these cars.
  1. Leather seat cleaning/maintenance
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-25-2008, 09:04 AM
  2. Dodge Dakota Maintenance
    By TyroElite in forum Off Topic Discussion
    Last Post: 01-28-2008, 09:29 AM
