Thread: How many BOV's on turbo intercooler setup
Results 1 to 9 of 9
  1. #1 Re: How many BOV's on turbo intercooler setup
    Jan 1970
    Maquoketa, Iowa
    No... Just 1 I would recommend reading up on how a BOV actually works, then you will understand
  2. #2 Re: How many BOV's on turbo intercooler setup
    GT Level Member rodman's Avatar
    Apr 2008
    i asked because i have z7 turbo and just got over sized intercooler....on zz websight it shows 1 on the intercooler side and one on the exhaust side.... confused...?
  3. #3 Re: How many BOV's on turbo intercooler setup
    SE Level Member Sinister Drag Designs's Avatar
    One is a wastegate, the other is a BOV. Both are Tial units.
  4. #4 Re: How many BOV's on turbo intercooler setup
    Apr 2008
    Thanks for clearing that up just bought intercooler and the bov may fix my stalling problem when getting off boost to fast
  5. #5 Re: How many BOV's on turbo intercooler setup
    Apr 2008
    So the bov does that tie into the waste gate line where map was???
  6. #6 Re: How many BOV's on turbo intercooler setup
    slc utah
    ha ha wastegate is for controlling boost by limiting exhaust flow into the turbo, when wastgate is closed (normal position) it lets all exhaust go straight to turbo and when rpm's go up turbo works harder and creates boost until a desired boost level then the wastegate slowly opens to keep boost at desired level and when you lot off gas the wategate closes again and thats when the blow off valve kicks in and will see vacuum and open up to vent excess air in charge pipes. reason for blow off valve is to keep your compressor from surging (basically turbine wheel will bounce back and forth very fast and will inhibit a broken shaft) and to relive pressure off throttle body plate and rod.
  1. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  2. New setup
    By b00stinGTX in forum Brakes/Suspension/Chassis
    Last Post: 02-25-2009, 11:00 PM
  3. Will this setup work?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2008, 03:29 PM
  4. A new road De-icer
    Last Post: 11-26-2008, 06:13 PM
  5. this setup
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2008, 08:47 PM
