Thread: F-Body/L26 fusion?
Results 1 to 20 of 21
  1. #1 Re: F-Body/L26 fusion?
    hangover park IL
    I doubt you'd see any difference. Power is majorly dependent on the turbo. The intake has very little effect on it.
    ...except for varying where the lean/rich cylinders are.....5,6 run leaner than 1,2 on the TR
    ~James~ Psychotic Gearhead
  2. #2 Re: F-Body/L26 fusion?
    May 2008
    Schuyler, NE
    Quote Originally Posted by Turbocharged400sbc View Post
    Is that due to air or fuel distribution?
  3. #3 Re: F-Body/L26 fusion?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I think the only really good advantage could be the ability to run a full phenolic spacer unlike any other intakes we have available, still get the hv3 results, and not have to relocate the battery or intake. Though, I'm probably the only one crazy enough to try it!
  4. #4 Re: F-Body/L26 fusion?
    Aug 2017
    Raytown, MO
    I'm guessing that's due to the fact our throttle body tilts forward towards the rear and a straight plenum tends to throw the air towards the rear and miss the closer runners? I've seen a few intake models and that seemed to be the case.
  5. #5 Re: F-Body/L26 fusion?
    hangover park IL
    Quote Originally Posted by wstefan20 View Post
    inertia is a *****. GN guys have played with this issue since the early days of the UIM power plates, meant to provide flow restriction for more even air distribution to all cylinders. early SI 3800's have a "ski jump" at the end of the TB adaptor where the air enters the plenum. this was changed in later SI production to the more modern low plenum wrapover runner (early are alum, later plastic) manifold design that was eventually applied across the whole range of GM V type engines due to cheapness of molding/die casting. everything is a result of compromises.....no compromise gives you the larger/harder to package Lehmann style intakes and the nearly perfectly even air/fuel distribution.....most modern high performance boosted engines use a variation of it...modified usually for easier injection molding of a plastic unit.
    Interesting! So you're saying that our overall stroke is too short to support airflow at high rpms?
    the whole engine is too short, to save $ and weight, GM circumcised an extra inch off the deck height it means a horrible rod stroke ratio, which means ****ty high rpm cylinder filling and drop in pumping efficiency. readup on rod/stroke ratio and youll see why indycar/high reving engines run a near 2:1 rod/ stroke ratio while our L67 has a horrible 1.5:1
    a hybrid SI/SII would allow for a 1.96:1 ratio....and even then the offset journal crank would make me leery of going over 7k
  6. #6 Re: F-Body/L26 fusion?
    Aug 2017
    Raytown, MO
    Wow! Lots of good info! So... I just realized you're the same guy on 3800pro forums! I just read your entire collection of posts on the series 1/2 fusion and I think I might want to go your direction. What ever happened to that project anyhow?
  1. Fusion fogs
    By ffball33323 in forum Visual/Body Modifications
    Last Post: 09-22-2015, 02:05 PM
  2. 2014 Fusion
    By Nates94 in forum Other Vehicles
    Last Post: 03-21-2015, 08:53 PM
  3. *HOW TO* Ford Fusion Fog's for GXP
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 09-09-2014, 03:27 PM
  4. Malibu vs Fusion
    By Madness in forum Off Topic Discussion
    Last Post: 06-28-2014, 09:23 PM
  5. 263 hp ford fusion
    By BlackGT97 in forum General Tech Discussion
    Last Post: 11-19-2011, 10:35 PM
