Thread: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
Results 1 to 8 of 8
  1. #1 What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Aug 2016
    MN
    Hey Guys,
    Do you know what gasket to use for mounting the wastegate on the CT kit on the rear manifold? I imagine one for a block off plate would be fine too. The only one at the parts store has ridges on both sides that go into the manifold and downpipe, but the plate doesn't have that so it's just trying to crush it instead which I would imagine makes a poor seal.
    Thanks!
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  2. #2 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Antioch, IL
    RA
    FEL-PRO
    61310
    If thats what your talking about its the oem manifold to pipe
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Aug 2016
    MN
    Is that what you're using? That's what the part store had, but it's not flat, it's rolled around the inside edges.
  4. #4 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Antioch, IL
    When I bought the ct kit used it had that gasket, I bought the one I linked last year to replace the old beat up one.
    As far as I am aware its just the stock gasket inbetween the wastegate perch and rear mani, nobody sells anything special or different.
    You can see the gasket when I first got the kit, has the metal ring on the inside
    Untitled by Corey S, on Flickr
  5. Thanks Mitch R thanked for this post
  6. #5 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Aug 2016
    MN
    Ok, here I was assuming we needed a flat gasket to get a good seal, but if that's whats working for you then that's what I'll use.
  7. #6 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Antioch, IL
    All work out good?
  8. #7 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Aug 2016
    MN
    Yes, I ended up getting a walker gasket as that was all the parts store had, but it was basically the same thing.
  9. #8 Re: What gasket for Rear Manifold/Downpipe block-off/wastegate mount
    Aug 2016
    MN
    Thanks!
  10. Likes ItHurtz liked this post
  1. Gasket replacement for Stock Manifold to 2.5" ZZP Downpipe
    By NotEnoughGPs in forum General Tech Discussion
    Last Post: 10-31-2016, 11:35 PM
  2. Rear Exhaust manifold to downpipe gasket
    By bigdan002001 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2016, 09:22 AM
  3. ZZP downpipe and rear ported manifold
    By Tonkin2000GT in forum For Sale - Parts
    Last Post: 08-23-2015, 06:28 PM
  4. close thread
    By DoubleBlown in forum Wanted To Buy - Parts
    Last Post: 07-09-2014, 03:38 PM
