Thread: Turbo recommendations/reviews
Results 1 to 20 of 40
  1. #1 Turbo recommendations/reviews
    Aug 2016
    MN
    Hi Guys,
    So I'm finally installing my turbo kit as the car has been sitting all winter and trying to decide which turbo to use. The kit I got came with the old cartuning Garrett T04-B in unknown condition/needing a rebuild. While I'm sure it would get the job done and would almost certainly be the cheapest, I'd like to at least weigh my other options before committing to the rebuild. I haven't been able to find out much at all about the Garrett turbo.
    I started looking for comparisons between the ones that come with the turbo kits for simplicity, the Garrett T04-B, the Precision PT-61, or the 6262, but I'm happy to hear about others as well. I'm trying to find that mythical balance of a fast spool time, but one that doesn't run out of breath if I do decide to take it to the track. If I had to choose though, I'd lean more towards a faster spool, since I rarely go to the track. So what have people used/what has been everyone's experience?
    Thanks!
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  2. #2 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    Imo, the T04 is small. The 6262 is a great turbo, but it's not cheap.
    For turbo sizing, we need to know how much power you want to make.
  3. #3 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    I was thinking 400hp, but I'm not exactly set on that. I'm not looking to break any records, just looking to make something fun to drive. I do plan to run a mild turbo cam like an ST1.
  4. #4 Re: Turbo recommendations/reviews
    when I ran my z7 kit, it came with a turbonetics T-66 and it took a 1-3 seconds to spool full boost at 13psi or above. just food for thought
  5. #5 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    Assuming that you're talking about whp, the pt61 will work well for 400.
  6. #6 Re: Turbo recommendations/reviews
    SE Level Member Blacknitews6's Avatar
    May 2017
    south jersey
    Man you give great advice on here. In my post you were a great help. And since i'm new here, If it's cool when i have any questions
    is it ok to PM you? Thanks for your help in my post. Appreciate it.
  7. #7 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    What is the expected hp of the T04-b? Sounds like it would only work for a mild turbo build, but boost would be near instant, similar to a blower. The T66 is a size up from the 6262, correct, so a 6262 would spool faster.
  8. #8 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    The t04 will max somewhere right around 400whp on our engines.
    Imo, the 6262 is better in every way than a t66.
  9. #9 Re: Turbo recommendations/reviews
    agree with the 6262. the T-66 was overkill for me on a stock motor, but the kick you get when it went above 13psi for full boost felt like vtec kicked in and losing traction anything below 40mph on street tires lmao. fwiw, I dynoed 392whp SAE on around 18-19psi with 19-20* timing
  10. #10 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    So either the Garrett or the 6262. Would the 6262 bolt up to the old cartuning kit?
  11. #11 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    No.
  12. #12 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    Well that makes my decision easier I suppose. Whats different about them?
  13. #13 Re: Turbo recommendations/reviews
    I would imagine the mounting bolts.
  14. #14 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    Cartuning kits are built around an on-center housing, vs a tanginal housing that the 6262 uses. It will physically bolt to the flange on your crossover (assuming you have a t4 kit) but nothing else will line up and you will have turbo clearance issues
  15. #15 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    Ok, so the 6262 is out then , I'm not buying a different kit at this point. The PT-61 must use an on-center housing then? Perhaps this is a stupid question, but it looks like the PT-61 is a generic number for that style/series, does anyone know the actual specs or part number that cartuning uses?
  16. #16 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    They used a few different versions of the pt61. You are correct, there are multiple versions of the pt61.
  17. #17 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    It looks like the pt-61 isn't even sold by precision anymore, it doesn't seem to show up anywhere. The one mention of it I did find was that the 6262 was its closest replacement. So what is actually included with the cartuning kits now? Do I have any other options?
  18. #18 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    Without having to redo your crossover, you can only find a used pt61 or have cartuning make you a new turbo.
  19. #19 Re: Turbo recommendations/reviews
    Aug 2016
    MN
    And here I was thinking I had all these choices, lol. Thanks for your help, might send them an email to at least get a price on an pt-61, I'm seeing a lot of folks really happy with it.
  20. #20 Re: Turbo recommendations/reviews
    May 2008
    Schuyler, NE
    I have a buddy that just pulled his pt61 and crossover off to upgrade. But he hasn't got on here yet to try and sell them.
  1. GPS Reviews Please
    By burgundybullet in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2013, 10:04 PM
  2. 05 gxp ????? reviews ?
    By joshv in forum Off Topic Discussion
    Last Post: 10-11-2011, 12:07 AM
  3. Goodyear Eagle F1 GS-2 Reviews???
    By JJ91284 in forum Tires & Wheels
    Last Post: 03-31-2009, 06:46 PM
  4. Parts/Shop Reviews
    By GreenNirvana101 in forum Forum Bugs/Suggestions
    Last Post: 04-14-2008, 01:16 AM
  5. Spark plug Reviews
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 10:06 AM
