Thread: Just got a turbo kit, couple quick questions
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 101
  1. #1 Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    First, let me say that I'm really glad I found this forum, there is tons of information here.
    I bought a used turbo kit for my L36 recently, getting ready to begin putting it all together. Right now my main focus is to get everything installed and street worthy. Eventually, I would like to upgrade the front and rear manifolds to PLOGS (including relocating the wastegate), as well as rockers or a mild cam such as an ST1 and 105# springs.
    The kit is an older cartuning kit that came with the Garrett T04-B, but the turbo needs to be rebuilt, so I am wondering if I should change/upgrade turbos or if this turbo would be good for my needs. I want a turbo that will have very little turbo lag. If not, what turbo would you recommend?
    For injectors, I will probably install 60# injectors right away so I know I have plenty of room to grow.
    I plan to get everything tuned by Overkill as I don't want to take the time to learn to tune myself.
    The turbo kit included the crossover, 2.5 downpipe, bov, wastegate, intercooler, and charge piping, and oil lines is there anything else I'll need that I might be forgetting?
    Finally, how much boost would be safe on 92 octane with this setup and what kind of horsepower should I expect?
  2. #2 Re: Just got a turbo kit, couple quick questions
    I'd just stick with that turbo, it'll work just fine.
    If you plan to stick with the stock MAF sensor you will run out of room rather quick, figure you'll be limited to under 14 psi for sure.
    I will say that a "canned" tune from overkill won't be very good, he'll just be guessing at this because the vehicle will not be infront of him. I wouldn't run one but that's just me.
    You'll want to invest in a scangauge and a wideband to make sure you don't blow it up. Also the stock transmission won't be the best friend of power for very long. Bigger fuel pump should be on your list of things too.
  3. #3 Re: Just got a turbo kit, couple quick questions
    Antioch, IL
    Why get a turbo and not learn to tune, but yet keep throwing mods to the engine requiring a guess tune each time leaving power on the table?
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    I shouldn't say I don't want to learn to tune, just that finding time can be hard. Eight years ago, I had the time but not the cash for a tuner. I'm in central MN and would be happy to pay someone local that's reputable to do.
    I will definitely rebuild the Garrett turbo then, much cheaper that way.
    If I wanted to upgrade the maf what's my best option?
  5. #5 Re: Just got a turbo kit, couple quick questions
    Antioch, IL
    Lt1
    lq selliot likes to blow apart
    and your online posting so you have time to learn and tune
  6. #6 Re: Just got a turbo kit, couple quick questions
    Quote Originally Posted by Mitch R View Post
    you can buy a dhp tuner brand new for 250. canned tunes cost about that dont they?
  7. #7 Re: Just got a turbo kit, couple quick questions
    I don't tune people cars but if people have there own tuners I could help but I am down in the cities.
    I own HPT but I'm sure I could figure out DHP, it sounds dumber than HPT haha.
  8. #8 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    I'll think about tuning it myself, but if my memory serves me correctly I still need a base turbo tune to get started or my tuning adventure will be very short lived.
    Is there anything else I'm missing to get this kit put together? I have a 255lph pump. What kind of boost/power should I expect to run with those mods?
  9. #9 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    I admit that part of it is not trusting myself to not royally screw it up, rebuilds are expensive.
  10. #10 Re: Just got a turbo kit, couple quick questions
    Antioch, IL
    stock pump with hotwire is good for 400whp.
    Until you cam and have it tuned I would expect 280-300slow whp, from there you just play with the BC.
  11. #11 Re: Just got a turbo kit, couple quick questions
    Kemmerer, Wyoming
    if it was me, and I was in your situation 6 months ago, I would just install the turbo and get the car running. I know a few people that installed turbo's with stock tunes. was it a good idea, probably not, but last I heard, both were still running and driving. the wastegate has a spring in it, and depending on the spring and washer combination, will dictate how much boost the wastegate will allow. typically they are set to 9 lbs or so. I would leave it there until you get the car running like you think it should, knowing the injectors and pump will be fine. the L36 maf is about the same as the L67, and you can get a thingy to change the range of the maf so it has a higher reading range, I forgot what it is called. also, I would recommend going the Hp Tuners route if you have an extra 700 bucks, or just get the basic for 500. the DHP can be bought for 250, but tuning with it is a slower process, and you will be limited on what vehicles it will work on, while Hp Tuner will work on many vehicles.
    on a different topic, more boost does not mean more power. like I said earlier, the cartuning kit is typically set to about 9 lbs. the eaton M90 makes about 6-8 lbs of boost, but because it takes power to make power, it will not make as much power as the turbo. so the m90 makes about 40 hp at 8 lbs of boost, then the turbo will make more than that at the same boost level.
    these are just rough estimates from off the top of my head.
  12. #12 Re: Just got a turbo kit, couple quick questions
    the timing on a l36 bin is way to high, a stock gtp bin would work much better.
  13. #13 Re: Just got a turbo kit, couple quick questions
    Antioch, IL
    Quote Originally Posted by SgtMarshal View Post
    your drunk the turbo makes more power than m90 not because its not belt driven, because it flows a **** ton of air AND cooler.
  14. #14 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Thanks for the wastegate info, i wondered what their standard setting was. I don't really like the idea of running the L36 programming, so I'm thinking I would still need a base turbo tune to get started, is there someplace to get one or is starting with the "canned" tune from overkill my best bet?
    Also, I would like to hit the 375 - 400 whp range, what other mods should I consider in order to get there?
  15. #15 Re: Just got a turbo kit, couple quick questions
    A built transmission.
  16. #16 Re: Just got a turbo kit, couple quick questions
    Aug 2016
    MN
    Lol, yes I did plan on that
  17. #17 Re: Just got a turbo kit, couple quick questions
    if your looking to make 400 hp just get a turbo. m90 builds tend to top out at 350 ish give or take.
    you cant run the stock l36 tune you'll blow it up. you "need" a tune. in car would be best tho as always, canned tunes are generic settings that has worked for other cars, but in the end every engine has its own needs.
  18. #18 Re: Just got a turbo kit, couple quick questions
    Kemmerer, Wyoming
    if you bought a tuner, you could load the cartuning turbo tune. I don't know anyone that uses it, but I imagine it would be a good place to start. you will need a 2 bar map sensor as well.
    Quote Originally Posted by ItHurtz View Post
    there are lots of reasons why a turbo is better than the m90, the belt drive is just one of them. and as far as cooler goes, I would defy you to prove a turbo runs cooler than a supercharger.
  19. #19 Re: Just got a turbo kit, couple quick questions
    no need to re prove that, the timing and boost a turbo can run is far greater then a m90. only way to come close is running corn and a small pulley, but you still make less power.
    turbo will win every time. even one thats set to only make 8 to 10 psi.
  20. #20 Re: Just got a turbo kit, couple quick questions
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Why would he need a 2 bar map...the computer is not mapped out for those values...and the cartuning tune is **** out of the box
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  1. Couple of quick questions
    By SpecialK in forum Introductions/Noob Questions
    Last Post: 01-15-2015, 08:14 PM
  2. Couple quick questions
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 06:30 PM
  3. couple of quick questions about tstats
    By pontiacgp759 in forum General Tech Discussion
    Last Post: 02-02-2010, 11:05 AM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. couple of quick downpipe questions.
    Last Post: 03-18-2009, 07:36 PM
