Thread: couple of quick downpipe questions.
Results 1 to 6 of 6
pontiacgp759 couple of quick downpipe... 03-18-2009, 06:50 PM
Guest Re: couple of quick downpipe... 03-18-2009, 07:17 PM
pontiacgp759 Re: couple of quick downpipe... 03-18-2009, 07:23 PM
Guest Re: couple of quick downpipe... 03-18-2009, 07:26 PM
pontiacgp759 Re: couple of quick downpipe... 03-18-2009, 07:34 PM
Guest Re: couple of quick downpipe... 03-18-2009, 07:36 PM
  1. #1 couple of quick downpipe questions.
    SE Level Member pontiacgp759's Avatar
    Feb 2009
    Ada, OH
    I'm going to order an offroad downpipe tonight. There are no emissions or anything like that, that i have to pass where i live. Anywho, question is, do i need an o2 simulator if i'm not going to get my pcm reprogrammed just yet? Also, what is the cheapest place you guys know of for buying my dp? I was assuming zzp. Finally, on a scale of 1-10, how hard is it going to be for me to get it on without any leaks? Thanks!
  2. #2 Re: couple of quick downpipe questions.
    TDCRacing
    Guest
    You don't NEED an o2 sim. But usually it set's a ses light.
    Just make sure you spray all the bolts down with PB blaster. It makes things a lot easier.
    Usually the downpipes have no problems sealing.
  3. #3 Re: couple of quick downpipe questions.
    Feb 2009
    Ada, OH
    thanks. it wont hurt performance? the person before me removed the ses light due to a loose gas cap. i'm guessin they thought it was something more major. I do have a spare simulator but it was for an LT1. maybe it's the same for my gp?
  4. #4 Re: couple of quick downpipe questions.
    TDCRacing
    Guest
    No problem! Nope won't hurt performance. The rear o2 is only there to make sure the cat is working properly. The front o2 sensor controls fueling.
    You could always try that spare one you have. Typically if there a 4-wire o2 then it will work. But i'm unfirmiliar with those.
  5. #5 Re: couple of quick downpipe questions.
    Feb 2009
    Ada, OH
    just ordered it. you, sir, just saved me 47 dollars i would have spent on a piece of plastic.
  6. #6 Re: couple of quick downpipe questions.
    TDCRacing
    Guest
    Well, Glad I could help!
  1. I have a couple of questions.
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-12-2009, 07:07 PM
  2. I Have a couple questions.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 08:07 PM
  3. I Swedish guy with a couple of questions
    By tdacke in forum General Tech Discussion
    Last Post: 05-14-2008, 05:27 PM
  4. quick questions
    By mexico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2008, 04:13 PM
  5. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
