Thread: What Turbo to run.
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: What Turbo to run.
    hangover park IL
    The seals might already be f*****. But since a restrictor is less than 50$...... it can't hurt to try vs dumping $ into a new turbo that you'd blow oil through if you don't get a restrictor to keep from pumping oil past the steel turbine fire rings.
    In terms of seals are none like you typically think of like say a rubber O-ring.
    The seals are nothing other than tight clearances and slinger rings/anti creep grooves on th rotating bits.
    the turbo Center section depends on good drainage with no back pressure to allow the oil to drain down through the housing once it passes the two shaft bearings/bushings.
    Push through too much volume or have a restriction in the drain and you end up pushing oil past the sealing rings
    ~James~ Psychotic Gearhead
  2. #22 Re: What Turbo to run.
    id use an on3 turbo. lots and lots of people are using them on mustangs and camaros andwho onows what else. everyine seems to claim they are good parts for the money.
  3. #23 Re: What Turbo to run.
    Kemmerer, Wyoming
    I would get a 58 to 68 mm turbo with an AR of .58 to .68. I don't know about turbo stuff but I do know turbo suisse is critical. I'm also not sure if the on3perf has a on center turbo housing, which is what you need.
    I was at the 1/8th mile track a couple weeks ago and an ls swapped mustang was running a low 7 sec time in an on3perf turbo
  4. #24 Re: What Turbo to run.
    SWPA
    Reading some of the first few responses are hilarious.
    eBay DOESN'T MAKE TURBOS or anything for that matter. Just because something is for sale on eBay doesn't mean its crap quality.
  5. #25 Re: What Turbo to run.
    SE Level Member drenolov's Avatar
    Nov 2014
    Has anyone had experience with cxracing
    Sent from my LG-H830 using Tapatalk
  6. #26 Re: What Turbo to run.
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Quote Originally Posted by drenolov View Post
    I was watching an episode of Hot Rod Garage last month or so and they put one of their turbos on an old Camaro. Ran good but they cautioned about the quality. Maybe slightly better than ebay turbos?
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  7. #27 Re: What Turbo to run.
    Nov 2014
    Quote Originally Posted by chrsmi1 View Post
    Ok I'm thinking about getting their Billet Gt35
  8. #28 Re: What Turbo to run.
    Kemmerer, Wyoming
    I've heard good things about the cx racing intercooler, but not their turbos. I couldn't say one way or another about cx racing turbos.
  1. Z3 Turbo Kit with New Turbo $2000 Shipped PRICE REDUCED
    By Swiggles in forum For Sale - Parts
    Last Post: 07-23-2016, 07:19 AM
  2. Need help finding Turbo rebuild kit or replacement turbo!
    By GHOSTOWLGRID in forum General Grand Prix Discussion
    Last Post: 08-10-2015, 10:30 PM
  3. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
