Thread: What Turbo to run.
Results 1 to 20 of 28
  1. #1 What Turbo to run.
    May 2012
    colorado
    I am looking for advice on what turbo to run. I am looking for a good street/strip turbo. I dont want anything to laggy since I am currently running a stock stall. Planning to run high to mid 11's. I was looking at these two ebay turbos
    http://www.ebay.com/itm/CXRacing-GT6...-/390793322360
    http://www.ebay.com/itm/T67-T4-Turbo...hWX5pg&vxp=mtr
    I know the ball bearing would probably spool quicker. But at what rpm do you think these would spool?
    I am kinda on a budget looking to spend around 450 dollars
    Thanks
    Matt-
  2. #2 Re: What Turbo to run.
    I break stuff selliott's Avatar
    Kansas City
    Just a little piece of advice don't buy a turbo off ebay
  3. #3 Re: What Turbo to run.
    Antioch, IL
    Turbo is not for budget minded people so good bye
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: What Turbo to run.
    Ebay turbo's work, the cheap cheap china chargers do fail but many others work just fine.
    You'd be surprised how many turbo's aren't made the US.
  5. #5 Re: What Turbo to run.
    May 2012
    colorado
    That was quick. Went to update my sig with mods and came back to 4 replies. Any help would be appreciated.
    2000 GTP: Stattama crossover, Stattama DP, Full zzp exhaust, Stattama Intake, s1x cam, 105# springs, Built block, FMIC, Tial WG with 10# spring, MBC, mini afc, HP tuners, E85, 60# INJ, PRJ fuel pump with rewire, LQ4 maf, Trans: stock stall, intense gen 1 lsd, hardened input shaft, upgraded clutchs.
  6. #6 Re: What Turbo to run.
    May 2012
    colorado
    Okay so what turbo would you recommend if not a ebay turbo. The reason I was looking at the ebay turbos is cause I have seen Quite A few ls builds with them and no problems. Ive searched ls1tech a ton and alot of the fbody guys swear by them.
  7. #7 Re: What Turbo to run.
    Kansas City
    What my friend is trying to say is there are some areas where you can cut corners but the turbo isn't really one of them. Ebay turbos have a nasty habit of coming apart violently and causing lots of damage with it
  8. #8 Re: What Turbo to run.
    Antioch, IL
    Ebay turbos have been known to explode above 15psi, 10psi I am sure you could run all day.
  9. #9 Re: What Turbo to run.
    I wouldn't spend $1,000 on a borg turbo for a grand prix that's for sure though.
  10. #10 Re: What Turbo to run.
    Kansas City
    Also true but there are enough turbo guys around here I'd rather buy one here
  11. #11 Re: What Turbo to run.
    Kansas City
    Do you already have a kit and just need the turbo or are you building your own?
  12. #12 Re: What Turbo to run.
    May 2012
    colorado
    I have a stattama kit with a unknown ebay turbo now with unknown mileage that is leaking oil. This turbo was given to me and the guy claimed it was a Precision but under further inspection it is not. Probably why he gave it away for free.
  13. #13 Re: What Turbo to run.
    hangover park IL
    Also drain hose routing/size and crank case pressure issues can exacerbate the issue
    ~James~ Psychotic Gearhead
  14. #14 Re: What Turbo to run.
    hangover park IL
    Big a/r t3 turbine side ~ 65mm exducer.
    It's hard to find a large T3 turbine housing since most of the Garrett housings are hard to find... but AGP still sells similar housings .82 ar t3 for 400 bucks but then you're still looking at 600 to 900 bucks for the turbo from master power/etc.
  15. #15 Re: What Turbo to run.
    hangover park IL
    If it's the stattama crossover you're probably stuck finding a small ar t4
  16. #16 Re: What Turbo to run.
    Kansas City
    Well maybe the ebay turbos have improved in quality, after I saw the damage from a couple of them exploding im a little gun shy. Listen to james he won't steer you wrong.
  17. #17 Re: What Turbo to run.
    hangover park IL
    Make sure you have an oil restrictor on some of those cheaper turbos as our engines pumps will over oil them and push past the seals
    Id recommend anywhere between a .070 to .080 orifice restrictor
  18. #18 Re: What Turbo to run.
    Kemmerer, Wyoming
    Www.on3performance.com cheapest turbo available with a stellar track record
  19. #19 Re: What Turbo to run.
    May 2012
    colorado
    It was leaking enough oil that it puddled up inside the downpipe and also came out if the cold side of the turbo. Do you think it could just be a oil pressure problem?
  20. #20 Re: What Turbo to run.
    May 2012
    colorado
    http://www.on3performance.com/shop/o...-turbocharger/
    Would this be a good choice for my goals? I am still pretty knew to reading turbo specs. Sorry for all the questions.
  1. Z3 Turbo Kit with New Turbo $2000 Shipped PRICE REDUCED
    By Swiggles in forum For Sale - Parts
    Last Post: 07-23-2016, 07:19 AM
  2. Need help finding Turbo rebuild kit or replacement turbo!
    By GHOSTOWLGRID in forum General Grand Prix Discussion
    Last Post: 08-10-2015, 10:30 PM
  3. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
