Thread: 500-600 WHP Build Questions
Results 1 to 20 of 42
  1. #1 500-600 WHP Build Questions
    GT Level Member Xorbex's Avatar
    Canada
    Looking to make 500-600WHP on PUMP gas. What size turbo and cam would be required. I have a GM 3800 Crate motor and will be putting a big cam and better flowing heads on it. Before everyone chimes in on a transmission DON'T. I am fully aware that I need a serious rebuild. This is a PROJECT car and will be built as a hobby over the next few years. I plan on sinking 10-20k into it. Please don't flame because I have no interest in entertaining you.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: 500-600 WHP Build Questions
    Feb 2013
    37.295091, -121.930053
    ok first off good luck making that much power. second how much do you want to spend because it going to cost alot of money to get 600 whp
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: 500-600 WHP Build Questions
    Canada
    Good luck? Arent guys getting 400-500 on the kits (no cam or headwork) and only pushing 14-17lbs of boost?
  4. #4 Re: 500-600 WHP Build Questions
    Canada
    I know I need a built tranny, thats not my question. I hate asking stuff and people going off in a completely different direction.
    Let me clarify, I am looking to build a Grand Prix with 500-600 HP. I know there are other weaknesses in the driveline and will deal with those properly. My question is what kind of cam, turbo, heads, intake, tb is it going to take for me to achieve close to my goals. I am doing this build over the next year or two so money isnt really an option. Of course i would love to save so cash and I will attempt that.
  5. #5 Re: 500-600 WHP Build Questions
    hangover park IL
    well making power at the engine is not a big deal the primary expense comes from the transmission. aside from our transmission someone could duplicate our turbo setup for less than four grand.
    ~James~ Psychotic Gearhead
  6. #6 Re: 500-600 WHP Build Questions
    Jan 2009
    Tallahassee, FL
    Don't forget the beefy tranny
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: 500-600 WHP Build Questions
    hangover park IL
    Most 500+ setups ive seen are over 18 psi.
    as I said making the power is not difficult the problem is is holding on to the power and getting it to the street using a glass drivetrain
  8. #8 Re: 500-600 WHP Build Questions
    Nov 2012
    Erlanger, KY
    Made 529whp at 17psi...
    Yocal ported/polished heads.
    Stattama T67 .68 AR
    ST5 cam and 130# springs (should have been 150#)
    200k mile short block
    Double Roller
    FBody intake with L67 TB.
    ZZP Plogs
    e85
    Hardly a "tune" on it, and 3 month old e85 in the tank.
    Nothing to fancy needed to break 500whp.
    Like everyone said its the transmission you gotta worry about.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  9. #9 Re: 500-600 WHP Build Questions
    Canada
    Quote Originally Posted by jdredd View Post
    Stattama T67 .68 AR
    Double Roller
    ZZP Plogs
    e85
    No problem spending 5k on a transmission when the time comes. A little disheatening to see you needed e85 to hit 529. Realistically I cant do e85 and I want this as a summer cruiser. Yes I know its not going to be that streetable with a huge cam but this is my choice.
  10. #10 Re: 500-600 WHP Build Questions
    Nov 2012
    Erlanger, KY
    Quote Originally Posted by Xorbex View Post
    With the 100% 200k stock bottom, e85 is the easiest choice for me. It's everywhere down here.
    I am sure I was getting close to 580whp at the track when I raced it.
    If its not around to bad, its great stuff and works wonders. I plan on running 750+ with it :P
    The ST5 cam probably didn't start showing its usefulness until passing the 20psi range and higher RPMs.
    You can make good power on smaller cams.
    All things considered the ZZP turbo cams are pretty tame compared to blower cams.
    The ST5 was perfectly streetable. No worse than driving around in my old S1X / PRJ LL cam.
    To me it felt baby sized still.. but thats turbo cams for ya I guess...
  11. #11 Re: 500-600 WHP Build Questions
    Jan 2016
    los angeles
    Jdredd, a lil of topic but did you ever do a turbocharged setup on stock heads and cam (L67/L32), your numbers are impressive just wanted to know what a baseline will be for a stock turbocharged GTP engines.
  12. #12 Re: 500-600 WHP Build Questions
    cam stock heads feed it corn 500 would be simple.
    big fuel system mega bucks in trans making 500 is not the hardest or most expensive part keeping a trans together is.
  13. #13 Re: 500-600 WHP Build Questions
    hangover park IL
    A "tiny" st1r cam. 130-150lb springs. dbl roller
    .82 ar t3 master power t70
    Barely ported heads.
    Barely ported f body intake. Stock l67 throttle body and maf.
    We did 608whp/575ft lbs at 18 psi at 5400 rpm maxing the walbro 255/90's
    Shooting fer 700+
  14. #14 Re: 500-600 WHP Build Questions
    4t80 trans alllllll the turbo 3800s haha!!
  15. #15 Re: 500-600 WHP Build Questions
    Kemmerer, Wyoming
    a zzp stattama turbo kit will make that much power
  16. #16 Re: 500-600 WHP Build Questions
    Banned
    CT
    Doing over 500whp on 93 octane is going to be a challenge. I'd put a lot of effort into your turbo choice and hot side piping.
  17. #17 Re: 500-600 WHP Build Questions
    Canada
    Yah im hoping to piece this together and do the pipe fab myself.
  18. #18 Re: 500-600 WHP Build Questions
    Banned
    CT
    If you can get really creative do tubular manifolds and try to fit a 3.5" downpipe. Also, don't be shy on the hotside A/R. .80-.90 is fine if you have a good cam and well designed headers.
    Most of your gains come on the hotside.
  19. #19 Re: 500-600 WHP Build Questions
    Canada
    All good info thx. Like i said this is a build in progress. I dont really care about the price because this is a project car. Some guys build GTO's or Vettes. I want a badass Grand Prix lol. Ill be getting my block on saturday. Paying $325 USD for a GM Crate 3800 still in the crate.
  20. #20 Re: 500-600 WHP Build Questions
    Banned
    CT
    I can appreciate your motives. Good luck, sir.
  1. Mild mod build questions
    By USonuMabeaCh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2015, 07:45 PM
  2. VS Build almost done just a couple of questions..
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2013, 01:53 PM
  3. Some Questions about doing a mild build L67
    By 88formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2012, 09:43 PM
  4. build questions
    By DaytonaGTP500 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 05:19 PM
  5. Exhaust Build Questions-before i buy
    By asite57 in forum General Tech Discussion
    Last Post: 07-04-2012, 12:56 PM
