Thread: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 85
  1. #41 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    almost ready
    Discovered a massive hole in the intercooler tubing.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  2. #42 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Just finished tuning the new turbo on my 26 X 10.5 X 16 MT ET street tires...
    Unreal, 22.5 psi of boost light up the tires bad till 3rd gear shift. Beautiful turbo sound, definately runs better.
    Very little lag... At 4K it's instant boost.
    With the same setup I used to flash to 5.5K now flash to 6.3K new the rev limiter on 2nd gear roll on sticky ET street tires.
    Pulls really hard, for sure it is much faster.
  3. #43 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Nice i run a 6466.
  4. #44 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Quote Originally Posted by 1999black3800 View Post
    Nice i run a 6466.
    BIG...
    So what is your best E.T. so far ?
    P.S. I wouldn't go any bigger than 6262.
    It's just the perfect turbo for street/drag combo. The GTX3076 was an awesome street turbo, so much fun, instant boost at any RPM.
    The 6262 requires a little RPM to get going. Since I have little traction, lag isn't noticeable as I just smoke the tires near the rev limit at any speed in 2nd gear.
    But if I had more traction, lag would be more noticeable for sure.
    I just looked at my logs and the GTX spools much quicker and harder.
  5. #45 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Banned
    CT
    Quote Originally Posted by TwinV6GTP View Post
    BIG...
    See this is exactly what I was talking about.
    You immediately ask what the best E.T. is so you can claim superiority with a smaller turbo.
    You have SIX HUNDRED POUNDS OUT OF THE CAR.
    You can't compare your setup to his unless you're talking about same day same dyno charts.
  6. #46 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Quote Originally Posted by SnowFlake View Post
    LOL take it easy mr Snowflake...
    One thing I know very well are turbos. And I can tell you right now most go WAY too big for nothing. Man who needs more than 650WHP in a FWD application other than the specialized drag car....
    Who needs bigger than 6262... It's overkill.
    I'm just curious why he posted about his turbo size and nothing else.
    Maybe he wants to teach me how much quicker his car is with his bigger turbo. I'd love to know if a larger turbo will allow a quicker ET in a similar car.
    Lets say he runs 11.2 @ 132 mph full weight (nothing removed) and still has NO lag... I will be impressed. I'm no dummy.
    But I know there is no way his car doesn't lag.
    I'm not one to claim I was full weight and say I run these times. I could have easily hidden this from you guys, but I don't believe in BSing people. That kind of stuff comes around.
    I put my cards on the table. I'm not even sure I have 600lbs out, between 500-600lbs I would say. But I could removed another 500lbs if I decide to spend money on the car.
    Some put money in the drivetrain, some in the chassis. I put nothing in both except of course for the turbo kit and free weight reduction.
    I have an 04 GTP daily driver. My 07 GT is now turbo and is going to be a true fully streetable car but just a little weight removed that does not affect my confort...
    This parts car has little value, but I'm getting a kick out of the fun factor for the money.
  7. #47 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Banned
    CT
    I can tell you that my car, his car, and anyone else's car that's posted in this thread would be slower with a smaller turbo on it.
    My 67 is actually a little small... I could run a 76 with some custom turbo headers, spool just as fast and make another 100whp on the same boost.
  8. #48 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Don't compare a DINOSAUR of a turbo like the T67 to a GTX3076. It can support more HP while spooling WAY WAY quicker.
    You have never felt anything like it. It's a Street killer. It has enough power to run mid 10s in a light car (maxed out, which I didn't do) and lows 11 on a heavy car.
    It spools instantly, harder than a 2.6 pulley on a M90. Fun factor = through the roof.
    This 6262 would be my first dual duty turbo (drag/street), it works awesome in both. But in no way is it as snappy and fun as the GTX3076. Cruising down the street 2000rpm in 2nd, instant burnout...
    This new turbo takes a second to light up.... not as fun.
    Imagine a 6466...
    So are you saying he'd be slower with a well tuned 6262 vs his 6466 ?
    Sure on a Maxed out drag car at 700WHP +
    But on a street/drag car ?
    No way...
  9. #49 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Banned
    CT
    Lol I told you I had a 67... you have no idea what kind of 67 I have.
    Regardless, a bigger turbo is more efficient. It flows more volume of air at lower temperatures at the same boost levels as a smaller turbo.
    The IATs on my setup are 20-30* above ambient... at 24psi.
    Your little gt30 turbo would be entirely out of breath and spitting fire.
    And with a properly spec'd cam, good exhaust, and tuning... the 67 spools instantly. Likely just as quick as the gt30 on your setup.
  10. #50 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Your little gt30 turbo would be entirely out of breath.
    GT30, turbine side yes. But a GTX3076 wheel ain't that small check the compressor map...
    BTW I ran 11.0 E.T. with a massive hole/gash in my intercooler tubing and I running 60% duty cycle on the turbo.
    But it was getting choked on the turbine side which is why I didn't push it, the converter is slipping so again why I didn't raise the boost.
    We'll go out one last time, see if the trans survives.
  11. #51 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Banned
    CT
    That turbo has a 58mm compressor wheel... My setup wouldn't even be on that compressor map.
    You're worried about spooling but we drive automatic cars and once it's spooled it stays spooled throughout the run.
    I stand by my original statement... any one of us would have a slower car if we ran smaller turbos.
    We don't run 50psi of boost, if you're making any power at all on our motors you're off the right side of that chart, not the top.
  12. #52 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Have you looked the compressor map ?? Size isn't everything.
    That particular billet wheel can produce over 600WHP... look at the chart.
    The turbine side is restrictive at that power level, but who needs 600whp in a street car FWD. Useless, even with ET street tires, which aren't even really streetable.
  13. #53 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    New 6262 turbo tuned and ready to rock... 22.x psi of boost.
    Please note speedo is still reading 20% low due to me adjusting the PCM for my smaller slicks. Never readjusted it...
    I let off at around 90 MPH
  14. #54 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Banned
    CT
    Traction has a lot to do with the suspension.
    My car hooks on the street in 2nd gear on an all season, during the day.
    vs a 540whp Grand National...
  15. #55 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    There is no way in hell you could hook the power I have currently on all season tires.
    22 psi of boost, 17 deg of timing, zero KR, pulls like a mofo.
    I don't care what suspension mods you have, you not hook if you ran the type of power I have currently in the car.
    I managed 1.7s consistently on a track with very little prep. Not bad for a FWD.
    Going to a real track this weekend.
    Have you been to the track yet ?
    26 X 10.5 X 16" ET street is pretty much a slick with a slightly stiffer sidewall and I light them up to 90mph.
    Don't get me wrong, while I light them up I'm still adding multiple bus lengths on a 14 second car in just a few seconds (chase car behind my car when I'm tuning)
    it's not like I spin and do go anywhere, it spins but goes hard. But it's nowhere near the traction I get at the track with true slicks MT of the same size.
  16. #56 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Nov 2012
    Erlanger, KY
    I only have an old dino Stattama mutt of a T67... makes for ok power I think, and no real problem with spooling I'd like to think.
    Still haven't gotten close to maxing it out yet. I should be able to dip into the 9's with it. Car as it sits is a little over 3000 lbs.
    Need to reweigh it as we took at a little more when it was like 3010... but then added a cage which was like 75lbs i think guy said.
    Now... my big retarded new Precision turbo .. that is a whole another story and interesting to see how many novels I can read while
    spooling..
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  17. #57 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Its not a particularly efficient turbo but it works just fine as you shown. I want your trans !!
  18. #58 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Oct 2012
    Albany, NY
    Look man. Your cars quicker then mine. I was just saying i have a 6466 sense i saw you have a 6262.
  19. #59 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    Oct 2011
    Toledo, OH
    Do they run 11s ? Don't think so...
    It was an older bike, not sure what it was, didn't really pay attention.
    There were other more recent big cc bikes only doing 10.7. Remember track was slippery so low 10s isn't easy even on a stock busa or ZX14
    My lightly modded '07 250 is faster then my '05 GTP off the line, and in the 1/4. That looked like an 80's style Ninja at least, and on my phone it looked like you had beat it by a LOT further actually.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  20. #60 Re: Project Parts cars Hits 11.0 @ 126mph and beats a Bike !
    May 2013
    Gatineau
    Quote Originally Posted by industrialfish View Post
    It ran high 11s. I beat it pretty bad. It was an 80s bike but I didn't look at it much, I was racing myself more than anything.
  1. Project Turbo Parts car !
    By TwinV6GTP in forum Turbo
    Last Post: 07-24-2014, 08:25 PM
  2. beats pro headphones
    By Matt Palm in forum Buy/Sell Other/Misc
    Last Post: 05-04-2013, 09:41 PM
  3. My project bike: it just got uglier.
    By Bio248 in forum Members Rides
    Last Post: 08-15-2012, 08:52 AM
  4. Clunking beats the Mechanics
    By Burley117 in forum Brakes/Suspension/Chassis
    Last Post: 03-21-2012, 11:06 PM
