Thread: Wheel stud
Results 1 to 18 of 18
  1. #1 Re: Wheel stud
    Quote Originally Posted by chuckfromcanada View Post
    was anyone able to get a front stud in on an 07 grand prix without removing the hub? if so please advise,thanks
    yup,
    you cant pound them back in, so you'll need to slide the new stud in then pull it in with a open lug nut on backwards, you may have to cut one side of the back flat part of the new stud to get it in behind the hub ring.
    it maybe be best to cut the old one short then pound it out so it comes out from behind the ring.
  2. #2 Re: Wheel stud
    Oct 2014
    Canada
    Wheel I got the broken one off no problem but the replacement wont clear the hole to get a nut on it..i have it positioned to the right of the strut , where did you line up yours? Was the stud as long as the others?
  1. Changing a wheel stud?
    By Z28 in forum General Tech Discussion
    Last Post: 04-13-2011, 03:30 PM
  2. Easy way to install a new wheel stud?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 08-12-2010, 05:44 PM
  3. How to fix broken wheel stud?
    By ryangtp89 in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2008, 10:59 PM
  4. &#@$ing Wheel Stud
    By Abrasive in forum The Rant Forum
    Last Post: 04-01-2008, 05:44 PM
  5. rear wheel stud-how to get it out and new installed?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2008, 03:47 PM
