Thread: question about pregens
Results 1 to 16 of 16
  1. #1 question about pregens
    GT Level Member yzboy85's Avatar
    Dec 2013
    maine
    I found a set of rims today at the junkyard that used to be on a 97 GT. However, they had the pontiac lettering on one of the spokes. That means they're pregens right? The similar fat 5 spokes from 97+ didn't have that lettering as far as I know. They look similar enough that I can't for sure tell the difference between them unless I see them side by side, but yeah..the lettering. If so I'm probably going to pick them up. Guy wants 100 for them and theyre in pretty good shape, probably an 8/10 after they get cleaned a bit.
    02 GTP Coupe - Jennifer
    SD headers, SLP Powerflo catback, 3.4, CAI, Shift Kit, GMPP Sway Bars, F-Body Brakes
  2. #2 Re: question about pregens
    If has lettering on 1 spoke they are 94-96 rims, so yeah pregens.
  3. #3 Re: question about pregens
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    These are pregens, be sure they arnt bent.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: question about pregens
    Dec 2013
    maine
    cool that's what I thought
  5. #5 Re: question about pregens
    Dec 2013
    maine
    anyone got any tips on cleaning up polished rims?
  6. #6 Re: question about pregens
    hangover park IL
    1st gen W
    lots of elbow grease.
    quick tip, and old hub bearing clamped in a vice makes a great polishing station
    and it works fantastic when you and your buddy take the bench mounted buffer and work that **** like pro's on a mission to aquire aluminum psychosis and injury
    ~James~ Psychotic Gearhead
  7. #7 Re: question about pregens
    Aug 2011
    'Merica
    Nice score.....polished pregens are not easy to come by.
  8. #8 Re: question about pregens
    Dec 2013
    maine
    what do I use to get surface rust off without scratching them up too bad? really fine grit sandpaper? or oxidation, or dirt, or whatever stuff is lol
  9. #9 Re: question about pregens
    St. Louis
    Don't use sandpaper! Maybe try Mother's Mag and Aluminum polish. Although not sure if it will cut through the clearcoat on those or not. The "rust" as you call it (fyi- alum. doesn't rust, lol...) is most likely brake dust and road grime. I've used Simple Green and also LA's Totally Awesome cleaner before to remove tough junk. The LA's can actually be found at the Dollar General, but works great. Used it on my engine bay as well.
  10. #10 Re: question about pregens
    Dec 2013
    maine
    yeah I realized right after I posted that (wait its aluminum derp), just looks like rust
  11. #11 Re: question about pregens
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    It is rust... only it's a built up layer of particles from the brake rotor thats been deposited on top of the aluminum.
  12. #12 Re: question about pregens
    SE Level Member DirkJr's Avatar
    Apr 2014
    East Peoria, IL
    I'm gonna be "that guy"
    Aluminum rusts almost instantly without the coating that it naturally forms. /endrant
    Using Tapatalk
  13. #13 Re: question about pregens
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    buy some rust off that crap actually works good. Spray it on and watch the rust run right off
  14. #14 Re: question about pregens
    Dec 2012
    troll land
    Pregen to what?
  15. #15 Re: question about pregens
    St. Louis
    To the 97-03 body style.
  16. #16 Re: question about pregens
    Dec 2012
    troll land
    Which since there are third gen ws roaming this forum wouldnt torque stars also b e pregens?
  1. I haz pregens.
    By Odi in forum Tires & Wheels
    Last Post: 11-28-2010, 07:39 PM
