Thread: Altima SER rims on a gp
Results 1 to 13 of 13
  1. #1 Altima SER rims on a gp
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    Found a deal on some 18s ser rims from altima has anyone seen them on a gp?
  2. #2 Re: Altima SER rims on a gp
  3. #3 Re: Altima SER rims on a gp
    May 2011
    El paso tx
    Really well that suck for other Nissan models like maximas and 350a will need a hub ring to fit them right
  4. #4 Re: Altima SER rims on a gp
    Figure our the stock specs compared to their specs and you'll have an answer.
  5. #5 Re: Altima SER rims on a gp
    Arizona
    hub bore is too small, won't fit over the stock hub.
    Wonder if one were to use something like a spring laded brake cylinder hone if you could make it work? Sounds like a hack job but **** its only a couple of mm that need to be sacrificed.
  6. #6 Re: Altima SER rims on a gp
    if you want to open up the hub bore of the wheel then by all means that will work.
    your other solution is to run a spacer to clear the 'lip' on the stock hub, but that isn't exactly a good solution.
  7. #7 Re: Altima SER rims on a gp
    May 2011
    El paso tx
    What's the worst case scenario that could happened if ran with spacer?
  8. #8 Re: Altima SER rims on a gp
    Florida
    Worst case scenario? Could snap the studs off, causing the the rim to come off in high fashion, and causing a wreck.
    Chances of that happening tho, very very slim.
  9. #9 Re: Altima SER rims on a gp
    you need a fairly hefty spacer to clear that lip on the hub.
  10. #10 Re: Altima SER rims on a gp
    Feb 2013
    37.295091, -121.930053
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  11. #11 Re: Altima SER rims on a gp
    May 2011
    El paso tx
    Gotcha going to pass then hated that most imports hub size is different
  12. #12 Re: Altima SER rims on a gp
    any machine shop worth their name can mill out the hub bore on a set of wheels in 20 minutes.
    but most people arent willing to do that kind of work on a wheel. it'll really affect resale value.
  13. #13 Re: Altima SER rims on a gp
    May 2011
    El paso tx
    I'm undecided because I have no idea how they would look on a gp, what you think are they worth it or not? Just want a different opinion
  1. Are 2002 Nissan altima rims a direct fit?
    By Bluemagic in forum Tires & Wheels
    Last Post: 02-21-2011, 12:51 AM
  2. Nissan Altima
    By spcguy88 in forum Track Sessions and Kills
    Last Post: 03-02-2010, 03:41 PM
  3. 03 GP GT vs 02 Altima
    By rocafella2032 in forum Track Sessions and Kills
    Last Post: 06-13-2009, 09:34 PM
