Thread: Would these rims fit a GP GXP?
Results 1 to 9 of 9
  1. #1 Would these rims fit a GP GXP?
    Jun 2012
    WBL MN
    I'm not to experienced with rims, more under the hood.
    The previous owner didn't take good care of the '05 GXP stock rims, so they are in ok shape, but not great. I'm going to make them my winter rims and am in the market for 20's. performanceplustire.com has some 20" Cragar's on sale through tomorrow for like $149 a rim, which is about $200 off per rim, but when I type in my vehicle they only give me the sedan-gt option under Grand Prix so the rims are 5x115 bolt pattern obviously, 20x9, 35+ offset, and the tire size choice is given automatically at 245/35R20. I'm not really worried about faster wear or a little less handling, I'm just worried about rubbing or not-fitting issues. Would I be better trying to order 2 pairs of rims and tires separate and keeping them staggered or would those fit fine? Thanks in advance.
    Edit: Sorry if this is already posted.
  2. #2 Re: Would these rims fit a GP GXP?
    I'm pretty sure those are going to rub big time.
  3. #3 Re: Would these rims fit a GP GXP?
    Arizona
    How would they rub if you're getting 35 series tire you'll be close to the o.d of the 45 series factory equipped plus the bilsteins have higher spring perches so the chance of rubbing is very minimal
  4. #4 Re: Would these rims fit a GP GXP?
    Quote Originally Posted by 91parkave View Post
    It is not the spring perch, it is the Fender that he would rub.
    But yeah just the rear fenders would need a roll, front should be okay, you may rub the liner on occassion with big bumps, no biggie.
  5. #5 Re: Would these rims fit a GP GXP?
    Arizona
    Quote Originally Posted by Drunkie View Post
    yea that makes sense arent GXP fenders wider though? ive seen alot of GXP's running 20's but never knew the size
  6. #6 Re: Would these rims fit a GP GXP?
    Because they are 20x9 with a different offset than stock?
  7. #7 Re: Would these rims fit a GP GXP?
    20x9 +35mm will fit decently.
    there's a good chance you'll have to roll the fenders. run the right sized tire and you should be well off, though.
  8. #8 Re: Would these rims fit a GP GXP?
    same body at the other 04+ cars. fenders are the same size.
  9. #9 Re: Would these rims fit a GP GXP?
    Yeah I wouldn't expect GM to change much on a car that they stamped out over 250,000 copies of.
  1. will G35 rims fit?
    By 3R1CD4V15 in forum Tires & Wheels
    Last Post: 05-26-2011, 01:22 PM
  2. Interested in changing my 04 grand prix gt rims for the Gxp factory rims
    By holt149 in forum Visual/Body Modifications
    Last Post: 02-21-2011, 01:41 PM
  3. Help With rims
    By LBGPRIX13 in forum Tires & Wheels
    Last Post: 08-10-2009, 08:07 AM
