I have a white 2004 Grand prix gt and im getting ready to buy rims and tires. I would like some input about which rims to go with.
I think i want to go with 19 or 20. What are your thoughts??
19s youre going to want to stay around 8.5" wide or less with an offset around +36mm or more.
20s youre going to want to stay around 8.5" wide or less with an offset around +40mm or more.
the tire size i would pick would be a 245 or 255 series tire that is the closest to stock diameter and maybe a little smaller to make sure you dont rub really bad. also, if you do end up rubbing you can roll the fenders which isnt all that bad. you need a rubber mallet and a heat gun. heat up the fenders and whack at it until the lip goes from 90* to more like a V.
Bio can you send me a pm explaining what offset is and all that junk. I'm veryvery un-educated when it comes to fitaments and you seem to know
send me a PM to remind me to respond to you. i am going to bed right now and i dont feel like it at the moment. if you send it tonight ill respond in the morning when i get to work.
