Thread: Yet another tire question...
Results 1 to 6 of 6
  1. #1 Yet another tire question...
    SE Level Member xbnb1978x's Avatar
    Jul 2008
    Attleboro, Ma
    I have an 08 Grand Prix . I just bought a set of rims Size: 18x8 Offset: +40mm ... What is the best tire size that will fit on my rims so they wont rub the fender or sidewall? Im trying to get them as fat as they can go and as low to the ground without a problem. Thanks!
  2. #2 Re: Yet another tire question...
    Barksdale AFB, LA
    If you change the rolling diameter (making it "lower"), you'll upset your speedometer's calibration.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Yet another tire question...
    Jul 2008
    Attleboro, Ma
    Help me out, im a newbie "idiot" when it comes to this stuff...
    Rolling diameter?
    Tire Size XXX/XXX/18 are you talking about the middle number when you say rolling diameter?
    Would the first set of numbers XXX be the width or the height of the tire?
    Would the second set of numbers XX be the width or height of the tire?
    Im not to worried about my speedo changing I have a Nav system that tells me how fast im going. Thats should give me the correct MPH speed Im at...
    but if thats going to mess it up that much. what would be a tire size you would recommend...?
    thanks
  4. #4 Re: Yet another tire question...
    Jul 2008
    Attleboro, Ma
    I think i got it.... 245/40/18 or 245/45/18...that should do it....
  5. #5 Re: Yet another tire question...
    Barksdale AFB, LA
    Rolling diameter is if you measured the actual diameter of the tire. This distance translates to so many revolutions per mile. If you change that, you have just thrown off your speedometer. It's not represented by any number on the tire, so you have to do the math to figure it out.
    Or you can use a handy tire calculator:
    Tire size calculator
    Input your old tire on the left, and new tire on the right.
    245/40/18 will throw you speedo off by 3.4%. When you're traveling 60, it will read 57.9 and the difference will get bigger the faster you go. The tire is too short.
    245/45/18 is almost exactly the same height as your current tires and the difference is so small you will never notice.
  6. #6 Re: Yet another tire question...
    Jul 2008
    Attleboro, Ma
    hey thanks for the help!
  1. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
  2. yet another tire question
    By Wadeb79 in forum Tires & Wheels
    Last Post: 06-03-2008, 06:59 PM
  3. Tire Suggestions
    By Risinnfallen in forum General Tech Discussion
    Last Post: 05-27-2008, 04:11 PM
  4. Tire sizing??
    By Quicksilver_GP in forum Tires & Wheels
    Last Post: 04-26-2008, 02:44 PM
  5. which tire would you guys get?
    By s1795so2 in forum Tires & Wheels
    Last Post: 03-27-2008, 08:11 PM
