Thread: tires/rims
Results 1 to 10 of 10
  1. #1 tires/rims
    Jun 2010
    ohio
    I have an 06 gxp.. now the front tires are bigger then the back factory I'm sure you guys may know, on the newer models are all four tires the same size on the gxp? also if I put all same size tires on the car will it affect the car at all?? I'd really like to buy all four of the same size tire and be able to rotate them so that they last longer.
  2. #2 Re: tires/rims
    Dec 2008
    Lawndale, CA
    All gxp's had the same size wheels and tires. There are many using the 18x8's all around with no issues.
  3. #3 Re: tires/rims
    New Mexico
    I have the Boss 18x8 rims all around and I have not had a single problem.
  4. #4 Re: tires/rims
    Norristown, PA
    Go right ahead an get you some tires
  5. #5 Re: tires/rims
    GT Level Member VDV18's Avatar
    Wishin I was at the Dunes
    Buy 2 more 18X8 alcoas and run the same size rims/tires all the way around.
    2006 Black GXP
    2006 Yamaha Raptor 700R - LRD Pro R4 Racing Pipe
  6. #6 Re: tires/rims
    Jun 2010
    ohio
    are the 18x8 alcoas the rims in the back? are the rims in the front bigger or wider then the back ones? is that why the front tires are bigger? or are the rims the same but the tire is widder?
  7. #7 Re: tires/rims
    SWPA
    If I remember correctly, its 18x8 up front and 18x7 in the rear. Pontiac did that to supposedly help handling. I myself think its stupid. As others said, get tow more 18x8's and run the 245/45/18's all around.
  8. #8 Re: tires/rims
    it helps handling because it helps the rear to rotate quicker in turns.
  9. #9 Re: tires/rims
    SWPA
    They wanted it to handle like a RWD. It still handles like a nose heavy FWD.
  10. #10 Re: tires/rims
    GTP Level Member joshv's Avatar
    canada
    i have 18x8 all around tires are 275/40/18 no issues
    2005 GXP / Cartuning Turbo Kit / meth / Cutout / Ported LS4 intake Manifold / HP Tuned / Custom 3" Cat-Back / Highflow Cat / SSC Springs / Poly Dogbone Mount's / 2nd Tranny /
    ( p/o track time12.6@109mph 1.7 60ft )
  1. Tires and rims
    By 04muscle in forum Visual/Body Modifications
    Last Post: 01-17-2010, 01:15 AM
  2. What rims/tires do i need?
    By dcwright02 in forum Tires & Wheels
    Last Post: 08-13-2009, 03:43 PM
