Thread: for those running 17s and bigger
Results 1 to 11 of 11
  1. #1 for those running 17s and bigger
    Donating Users
    Idaho Falls
    Did you notice a rougher ride? I am planning on getting new rims but I am thinking 17s for the mere fact of a little more sidewall. I will not be doing any racing with this car for a couple years (well any autocrossing).
    Is there a noticable difference in a 17 or an 18 as far as the ride goes?
    I realize the tire affects the ride and the sidewall height but I am talking a simple +1 or +2 type of conversion.
    Really not sure what wheels yet I have looked at alot and haven't found any I like yet
  2. #2 Re: for those running 17s and bigger
    West Side Michigan
    I have 235-55-17's Pirelli P-Zero Nero tires and honestly, I thought they were just as smooth if not smoother then the stock 225-60-16's.
    I've had some rough tires on the 18's I've had and some smooth ones. I would definitely recommend you look at tire reviews and see which are smoother and better rides.
  3. #3 Re: for those running 17s and bigger
    I feared going to 18's for the smaller sidewall. However the ride of a GP/Regal on fresh suspension and the 18's feels much like the stock GP feel with less bounce.
  4. #4 Re: for those running 17s and bigger
    ride has to do a lot more with the suspension than the tires.
    your tires, depending upon size, will attribute to road noise, turn in (how long it takes the tires to actually catch the conrete after they begin to roll sideways), feel of the road, and tram lining (when the tires ride in the grooves of the road). the wider tires you go the more you'll notice these things.
    yes, tires with smaller sidewall you'll be able to 'feel' the road more, but it shouldn't be much rougher than stock.
  5. #5 Re: for those running 17s and bigger
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    I'll argue that one till I'm out of breath with my 19's.... Yes you will feel the road more with the smaller sidewall, hitting potholes and such or going over rough surfaces the smaller sidewall will only enhance it where as a larger sidewall tire will "absorb" some of it.
  6. #6 Re: for those running 17s and bigger
    i dont disagree with you, i just think people make it out to be more than it is.
  7. #7 Re: for those running 17s and bigger
    Norristown, PA
    My 18s ride rougher. But I'm used to it
  8. #8 Re: for those running 17s and bigger
    Minnesota
    yea i have 20x9's and its a little rougher but only really on rough roads and potholes otherwise besides like turning corners feeling a bit different
  9. #9 Re: for those running 17s and bigger
    Donating Users
    Idaho Falls
    One of the other reasons I think I may just stay with 17s is I do live in Idaho, gravel road driving is not uncommon for me.
    I think I would end up going really slowly on some roads that I travel on sometimes just because I had 18s if I went with such.
    Thank you guys for all the advice, I appreciate all the different points of views
  10. #10 Re: for those running 17s and bigger
    SE Level Member gaprix04's Avatar
    New Jersey
    I'm riding 245/35/R20 in the summer and the ride is a lil rough when I change from the stocks but it smooths out after about 200 miles.
    "If there must be trouble, let it be in my day, that my child may have peace."
    Thomas Paine
  11. #11 Re: for those running 17s and bigger
    GTP Level Member SuperSport's Avatar
    Michigan
    For me it was smoother going to 17s from the 16s. But like others have said suspension attributes to handling.
    Road noise affected mine the most. Then again my new 17s have Yokohama tires and I took off 16 inch Goodyears. Of course theres going to be less road noise lol.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. Open Cone need bigger pulley?
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2010, 07:10 PM
  2. Putting bigger motor in.
    By CMURDAx in forum General Tech Discussion
    Last Post: 12-30-2009, 07:26 PM
  3. how do i make my sig pic bigger?
    By nicksilvergt99 in forum Off Topic Discussion
    Last Post: 10-15-2009, 06:22 PM
  4. High Amp Alt vs. Bigger Cap
    By adidasdude1061 in forum Audio, Security & Visual Electronics
    Last Post: 04-19-2009, 04:52 AM
  5. I think I am going to need a MUCH bigger hood now!
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 05-14-2008, 10:29 AM
