Thread: what can i do with these wheels?
Results 1 to 20 of 20
  1. #1 what can i do with these wheels?
    GT Level Member gpgt04's Avatar
    MA
    there a set of 18" eagle alloy ae077's. ive already polished them with with mothers mag and aluminum and a power cone. what is this stuff i cant seem to get rid of? pitting?
    [IMG][/IMG]
  2. #2 Re: what can i do with these wheels?
    MA
    anyone?
  3. #3 Re: what can i do with these wheels?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    try some rubbing compound
  4. #4 Re: what can i do with these wheels?
    Kansas
    Are those chrome? If they are chrome its always better to let them breathe and not put stuff on them like wax and stuff. Soap and water is always good. But if that stuff won't come off go to a rim shop they should have this little plastic container of wheel cleaner. Its like a blue clothe like material and you just rub it on the surface and it fights deep in the wheels and cleans anything off
    SOLD 1999 GT Silvermist TS
  5. #5 Re: what can i do with these wheels?
    MA
    im pretty sure there just polished aluminum
  6. #6 Re: what can i do with these wheels?
    Akron Ohio
    you cant get this out, I tryed for 2 hours on my rims. sorry I know it sux
  7. #7 Re: what can i do with these wheels?
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    well if your putting those on your GP i want your stockers
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  8. #8 Re: what can i do with these wheels?
    Kansas
    Take them to a wheel shop i guarantee that they can help
  9. #9 Re: what can i do with these wheels?
    Joliet, IL
    get them powdercoated silver.
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  10. #10 Re: what can i do with these wheels?
    MA
    thought about that. what the going rate per wheel?
  11. #11 Re: what can i do with these wheels?
    Joliet, IL
    shyt if i know call some body shops around your area.
    00 Silvermist GTP
  12. #12 Re: what can i do with these wheels?
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Since the finish is already messed up, try a fine sandpaper, like 600/800 grit paper on a small area and see if it removes the oxidation (just to see if there is any improvement). If you do see an improvement, expand on the area and polish, it's going to be a little bit trial and error in the beggining, but if it does bring the shine back, be prepared for alot of work.
  13. #13 Re: what can i do with these wheels?
    MA
    i tried 1k grit and it just dulled it a little bit and couldnt really get the shine back. guess im gonna look into powder coating
  14. #14 Re: what can i do with these wheels?
    Apr 2009
    Carlisle PA
    Quote Originally Posted by gpgt04 View Post
    You have to get past the oxidation, 1000 was probably too fine of a paper to actually do anything.
  15. #15 Re: what can i do with these wheels?
    MA
    hmmm ok i'll give this a try sometime this week i'll let you know how it turns out
  16. #16 Re: what can i do with these wheels?
    SE Level Member 00GTCoupe's Avatar
    Leeds, Maine
    Do those have a clearcoat on them? It's hard to tell in that pic, but it looks that way.
    I had a set on Outlaw II's that I used a paint stripper on to remove the clearcoat, then polished them. They came out great.
    I know it's extreme, but if you're thinking about painting them, it might be worth a shot.
  17. #17 Re: what can i do with these wheels?
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    It looks the the clearcoat is cracking. If they are aluminum and it was just pitting the 1000 grit or polish should have brought it back.
    Lambokit to be built!!!!!
  18. #18 Re: what can i do with these wheels?
    Apr 2009
    Carlisle PA
    Looking up Eagle 077's, the description said it's "chrome", which I don't think is an actual chrome but the same process you see with Eddy intakes - it's called Permastar or something close to that. It's a coating - the company who started it I think was "Goodrich", alot of chrome like wheels use the same process, very durable. You might want to call Eagle Alloy and see if they can think of anything you can do. But I think you might be SOL, or as stated before, paint or powder coat.
    Here's some reading if ya want.
    http://www.permastar.com/service.htm
  19. #19 Re: what can i do with these wheels?
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    I would just get them powdercoated, they have colors now that almost look chrome/polished. Screw all that work.. haha
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  20. #20 Re: what can i do with these wheels?
    SE Level Member slow94formula's Avatar
    MN
    Powdercoating FTW.
  1. Wheels for DR's????
    By PWNED in forum Tires & Wheels
    Last Post: 04-27-2011, 10:22 AM
  2. New wheels
    By ctrout in forum Visual/Body Modifications
    Last Post: 02-17-2010, 03:40 PM
  3. Are these g6 wheels?
    By Sheepdog in forum Tires & Wheels
    Last Post: 10-04-2009, 12:11 PM
  4. GXP Wheels
    By bladerunner in forum 5.3L V8 (LS4)
    Last Post: 06-30-2009, 05:32 PM
