Thread: Help Removing Wheel
Results 1 to 20 of 24
  1. #1 Help Removing Wheel
    SE Level Member Lowdown112's Avatar
    Dec 2012
    Louisville
    How do I take off a wheel without power tools..and the car is in the air so when I try to turn it the wheel spins.. I also cant put the car on the ground.
    Correction: Lug Nuts off the wheel.
    Situation: I went looking for new front bumper at my local junkyard. Found one in great shape. Then I went looking for the door light housing cuz mines are broke. Found some and also found a grand prix that caught fire somehow but it has great stock rims on it almost perfect condition. Isnt wrecked or anything. These are the wheels. But they say no power tools and the car is sitting up in the air, not on the wheels but there are other rims under the body holding it. I couldnt get them today..but im bringing my buddy along tomorrow. I am going to get those wheels...
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Have someone hold the wheel?
    Or have them press the brake in the car? I dunno that's odd. They shouldn't free spin.
    Have your buddy jump in the car and press the brake in as long as someone didn't jack everything and then bring a breaker bar and you'll be set.
    04 Comp G.
  4. #4 Re: Help Removing Wheel
    Dec 2012
    Louisville
    Thanks guys ill try! But ill definitely get them somehow
  5. #5 Re: Help Removing Wheel
    if the car has no brakes, try a ratchet strap tight around the tire, then tie off the left over strap to keep it from turning.
    if the tire spins in the strap, let air out of the tire so the strap squeezes the tire.
  6. #6 Re: Help Removing Wheel
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Run a long pry bar through the rim and stick it in the ground or wedge it somehow.
    When the wheel starts turning the bar will wedge itself and stop the turning.
    Wrap the bar with something so it doesn't scratch the rim.
    Also spray the nuts with PB Blaster.
    1997 Red GTP 182000 miles stock
  7. #7 Re: Help Removing Wheel
    GT Level Member 00GT's Avatar
    Dec 2011
    Michigan
    For the rears you can just put the parking brake on. For the fronts you'll probably need someone to push the brakes or hold the wheel.
  8. #8 Re: Help Removing Wheel
    Jan 2012
    Philadelphia
    Or you can just leave it on the ground and brake the lug nuts loose then jack it up
    Quote Originally Posted by gtpeddie View Post
    Of course that's the normal way but OP stated car was in the air so Im assuming his either not able or doesn't want to go through the hassle and put it on the ground especially at a JY.
    04 Comp G.
  10. #10 Re: Help Removing Wheel
    Omaha, NE
    Skips first post, criticizes people who read it anyway.
    As mentioned have someone hit the brakes or wedge the wheel with a prybar, exhaust pipe, crossbraces anything you can think of.
    Another method would be to use a ratchet or breaker bar with a 19mm socket and a decent size hammer. That should break it loose enough to spin it the rest of the way off, again someone on the brakes is going to help.
  11. #11 Re: Help Removing Wheel
    Dec 2012
    Louisville
    Imagine this, one rim laying flat with an upright rim welded to it, with the car sitting on it. Its a good 3-4 feet in the air.
  12. #12 Re: Help Removing Wheel
    I live here. DirtDog's Avatar
    Jun 2012
    wait...is that actually how it is...the car been sitting on rims like that...im confused
  13. #13 Re: Help Removing Wheel
    Dec 2012
    Louisville
    Yeah..idk why
  14. #14 Re: Help Removing Wheel
    Jun 2012
    like that...but with top rim actually mounted to the car wtf
  15. #15 Re: Help Removing Wheel
    Dec 2012
    Louisville
    Yes like that, but those 2 rims are welded together and the car is just sitting on top of them
  16. #16 Re: Help Removing Wheel
    Jun 2012
    im so confused here
    Bunnell, FL
    The car is at a junkyard
    I'm a Sex Offender
    Jun 2012
    O i missed that part
    Sent from my DROID RAZR using Tapatalk 2
  19. #19 Re: Help Removing Wheel
    Dec 2012
    Louisville
    Got em off, lovin them. Not doin anything to them until febuary gets here.
  20. #20 Re: Help Removing Wheel
    Dec 2012
    Louisville
    Here is what came from this post BTW just a follow up- spent 130$
    Played with some plastidip!
  1. removing steering wheel radio controls
    By JesseBranham in forum General Grand Prix Discussion
    Last Post: 10-29-2012, 06:41 PM
  2. Removing a steering wheel.
    Last Post: 08-28-2012, 08:58 PM
  3. Did my wheel bearing/hub got messed up?? after removing and replacing
    By Haulero in forum General Grand Prix Discussion
    Last Post: 06-10-2012, 03:25 PM
  4. Removing steering wheel
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 08:02 PM
  5. need help removing rear wheel bearing hub assembly
    By tiedye in forum Off Topic Discussion
    Last Post: 04-26-2011, 07:15 AM
