Ok, so how do you get the lug stud in without removing or at least loosening the hub. I can't get it to go in anywhere no matter where the hub is turned.
Also it says in the shop manual that if you remove the caliper bracket bolts they must be replaced with new fasteners, I'm guessing I see the reason why. I was putting the caliper bracket back on so I didn't have to hang it from wire or remove the hose and I notice that the bolts screw into the caliper bracket, but the other piece that the bolt attaches to isn't grabbing. Never heard of a one use bolt. I guess it must wear down the threads so that it can't be used again, cause the bolt in the other piece just slides in and out. And I haven't stripped any threads in this case.
I say this cause I notice that the hub bolts say this same thing. If you loosen or remove them that they must be replaced with new fasteners.
