[QUOTE=Scottydoggs;1454591]not sure if the back is like the front, tight to get the new lug in, what we do for the front is cut one side of the backing part off so it can slide past the ring where the studs go. then use a lug nut on backwards ( flat side to the hub) to crank it in place Thanks Scotty!
