Thread: Cold Air Induction
Results 1 to 16 of 16
  1. #1 Cold Air Induction
    SE Level Member georgeo's Avatar
    Jun 2014
    Colorado
    Just because there is fancy chrome piping and an open element air filter, does not make it cold air induction.
    By default, unless it is taking air from the outside of the vehicle, it is only sucking under hood temperatures. Yea, this kinda grinds my gears.
  2. #2 Re: Cold Air Induction
    Dec 2012
    Where 4T65E's were born
    We like to call them hot air intakes (HAI)
    Sold.
  3. #3 Re: Cold Air Induction
    HUDSON
    That's why I like the factory air filter box on the 2000s, it takes the air directly from behind the headlight assembly, and also it helps keep the air sucking noise quite.
  4. #4 Re: Cold Air Induction
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    My HAI sees the same IAT temps as my stock box did while crusing. Even after sitting then going they drop right down to usually 10 to 15 off ambient temps. Plus the HAI doesnt get heat soaked compared to what I saw with the stock box.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Cold Air Induction
    Aug 2013
    McDonald PA
    It just sounds cooler with a hai
  6. #6 Re: Cold Air Induction
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    When you say 10-15 off ambient you mean hotter than ambient?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  7. #7 Re: Cold Air Induction
    Apr 2012
    Dayton, OH
    Yep
    2012 F150 STX
  8. #8 Re: Cold Air Induction
    Jan 2014
    AR
    To avoid confusion I use the term open element air filter just like you, georgeo. When I first came here, an HAI was suggested and I laughed pretty hard. Who would want a hot air intake? No one explained but I figged it eventually. And invented a solution to suit myself, as we all do. What I still havent figured out is why front control arms are called LCAs here.
  9. #9 Re: Cold Air Induction
    The Boss Iceman6669's Avatar
    Jun 2011
    LCA = Lower Control Arm
    2011 F-150 Yote powered
  10. #10 Re: Cold Air Induction
    Jan 2014
    AR
    But theres no upper. So its just a control arm to me.
  11. #11 Re: Cold Air Induction
    Buffalo, NY
    Yep
    huh interesting. I always wondered what the temp with those was. I have a zzp intake and it's usually 1-2 below ambient at 30-40 mph and 50+ drops to 4 or more cooler than ambient. Not that that makes it a cold air intake but that's more of a difference than i thought it'd be.
  12. #12 Re: Cold Air Induction
    Jun 2011
    I would REALLY like to see someone measure post blower temps with both. I would be willing to bet the temps are the exact same or VERY close.
  13. #13 Re: Cold Air Induction
    Buffalo, NY
    I'm n/a if that was a response to my post. If not I would like to see some too haha
  14. #14 Re: Cold Air Induction
    Jun 2011
    Not in response to any post. Just saying that I bet for Blower Cars there is little to no difference
  15. #15 Re: Cold Air Induction
    Quote Originally Posted by Iceman6669 View Post
    Shove a temp sensor in the LIM.
    Otherwise, I'd venture that the temps are ignorantly hot on ANY non-intercooled or meth injected setup.
  16. #16 Re: Cold Air Induction
    Jun 2014
    Colorado
    I like it (hai) hot air intake. Agreed, it does sound cooler, ohhh I get it cooler. So... in the convoluted universe that I live in, (sci-sounds cooler induction) makes perfect sense in that the cool sound of the air rushing through the open element filter could indeed compensate the lack of lower air temps with unadulterated audio pleasure.
    I'm just tugging the snargly's folks. I have seen an induction system for the GXP that routes the air from the inner left fender which circumvents the old school forced air but gives credence to the old school forced low pressure area. This would be the difference between the 70 SS Chevelle and the 70 442 W-30 forced air setups one takes it from the cowl and the other is force fed from the front. The mathematics are maddening. Yes, that's why we have huffers and puffers.
  1. cold air induction
    By getsumi shin in forum General Tech Discussion
    Last Post: 08-05-2011, 09:03 PM
  2. Cold air induction systems - differences
    By GPrixGT00 in forum General Tech Discussion
    Last Post: 05-07-2011, 09:23 AM
  3. Custom Cold Air Induction [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 07-04-2009, 05:05 PM
  4. Cold Air Intake mitigated by forced induction?
    By Chernobyl in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2009, 02:28 PM
