Thread: digital boost gauge
Results 1 to 8 of 8
  1. #1 digital boost gauge
    Sep 2013
    Northwest Indiana
    I'm assuming the boost gauges that come in the dic max out at Whatever psi, and my car has a 3.4 pully so it max's out at half throttle, now that dosent mean I'm at like max for that pully correct? I'm guessing the ones in the gp's are more of a light show?
  2. #2 Re: digital boost gauge
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    umm stock gauge is set for like 6ish PSI with a 3.4 you are prbly around the 9 to 10 PSI mark... so at about half throttle it will go full cause u are registering the 6ish PSI of boost
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  3. #3 Re: digital boost gauge
    Other mods?
    Sorta sounds like you might not understand your engine very well here, you might be causing harm to it.
  4. #4 Re: digital boost gauge
    Get a real gauge to show boost
  5. #5 Re: digital boost gauge
    SWPA
    You don't even need a boost gauge on a supercharged car. That is why it is buried in the DIC.
  6. #6 Re: digital boost gauge
    my regal will show over 8 psi, bone stock only if its like 5 deg's or less outside ill see 8.5. in warm weather i see 6.5 to 7 tops at the shift points. one day ill find out if it reads higher.
    but then again i dont know when the last time i even looked at my boost gauge lol if you hear it whine, your boosting.
    them lego blocks seem to be worthless anyway. the regal gets a true digital read out, the sports car gets a dummy lego blocks display, way to go GM!
  7. #7 Re: digital boost gauge
    Hi fives a fellow Regal driver..
  8. #8 Re: digital boost gauge
    Jul 2012
    Chicago
    And Bonnevilles get real boost gauges. :P
    -Carl
  1. digital boost guage
    By johnpstuart in forum General Grand Prix Discussion
    Last Post: 03-01-2013, 09:55 AM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
