Thread: Blower Module Removal
Results 1 to 10 of 10
tdm571 Blower Module Removal 05-31-2011, 11:35 AM
TheOtherNick Re: Blower Module Removal 05-31-2011, 12:09 PM
tdm571 Re: Blower Module Removal 05-31-2011, 12:57 PM
tdm571 Re: Blower Module Removal 05-31-2011, 08:56 PM
Remnant King Re: Blower Module Removal 05-31-2011, 09:47 PM
TheOtherNick Re: Blower Module Removal 05-31-2011, 09:49 PM
Remnant King Re: Blower Module Removal 05-31-2011, 09:50 PM
redlinepontiac Re: Blower Module Removal 05-31-2011, 09:57 PM
Ravenwald Re: Blower Module Removal 06-01-2011, 01:41 AM
tdm571 Re: Blower Module Removal 06-01-2011, 07:47 AM
  1. #1 Blower Module Removal
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    ! Could they have made it any hard to get that last f---ing screw out to replace the d--n thing. I mean, seriously, it's not like those things are rock solid. They seem to go bad quite often. So why not make it just a little bit easier to remove. Phew. I few much better now. Time to go piss myself off trying again to get that last screw out.
  2. #2 Re: Blower Module Removal
    Charles City, IA
    They take less than 10min to do.........
    SMGPFC Two Nipple General
  3. #3 Re: Blower Module Removal
    Lakeside Park, KY
    Except for the one screw. I can't get anything on it to loosen it
  4. #4 Re: Blower Module Removal
    Lakeside Park, KY
    Finally able to get my socket on the d--n screw. Didn't even bother to tighten it back up. When the thing blows again, I'll remove the front screw and pull it out since the back two are slotted. What a big PIA!!!!!
  5. #5 Re: Blower Module Removal
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    Did you bother to remove/loosen the Alternator?
    It makes things a whole lot easier.
  6. #6 Re: Blower Module Removal
    Charles City, IA
    all you do is remove the front screw, and pull it out with a pair of pliers, breaking the back tabs off. Then loosen the back bolts with a wrench and slide the new one in.
  7. #7 Re: Blower Module Removal
    Nov 2010
    Michigan
    I am most likely mistaking that with something else, my bad.
  8. #8 Re: Blower Module Removal
    Waukesha, WI
    are you talking under the pas side of the dash?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  9. #9 Re: Blower Module Removal
    GT Level Member Ravenwald's Avatar
    May 2011
    Fort Myers, FL
    Yah, I had to remove my Blower Motor from the Dash. It was a PITA. I also had to replace the resistor. All thanks to that rubber drain over the HVAC intake coming loose. Good times.
  10. #10 Re: Blower Module Removal
    Lakeside Park, KY
    Yeah, the blower motor module under the passenger side dash. I just managed to get my socket on it to loosen it enough to pull it forward. Major PITA.
  1. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  2. blower motor control module
    By mtz956 in forum General Tech Discussion
    Last Post: 10-03-2010, 10:00 PM
  3. blower removal
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2009, 06:28 PM
