Thread: Home Depot DIY CAI not happenin!!
Results 1 to 20 of 34
  1. #1 Home Depot DIY CAI not happenin!!
    GT Level Member Xorbex's Avatar
    Canada
    Ok well this is how I see the story unfolding. I want to "improve" the flow on my CAI on a 05. After leaving the plumbing section at Home Depot, I had gotten a few items for a 4" intake (they looked way too big.) Then after measuring and looking decided that it wasn't going to work I admitted defeat. Another trip to Home depot to switch the items for 3", now I'm excited looks like it may work. First thing I did when I got home was open the hood...... damn that will just make things way more restrictive. Anyways I have decided that no upgrade is going to happen unless 3.5" parts are found.
    Thanks for listening
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Home Depot DIY CAI not happenin!!
    ebay mang, you can find 3.5in rubber tubes on there, alot of people but that size for intercooler piping on massive IC's
  3. #3 Re: Home Depot DIY CAI not happenin!!
    Jul 2008
    Tampa, FL
    yeah, if you give up...the man wins. stick it to the man, man!
  4. #4 Re: Home Depot DIY CAI not happenin!!
    Canada
    I almost beat the man but murphy showed up.
  5. #5 Re: Home Depot DIY CAI not happenin!!
    London Ont, Canada
    I will see what my Non backwater HD has available lol as I plan on doing the same, you got a cone already? where and $$?
  6. #6 Re: Home Depot DIY CAI not happenin!!
    Canada
    I bought a cheap intake with filter off of ebay and connected it to my maff tubing. I'm looking to remove the accordian tube and replace it with a better flowing piece. I have to measure it properly first so I know what size to get.
  7. #7 Re: Home Depot DIY CAI not happenin!!
    Jul 2008
    Tampa, FL
    that is so weird, bc my 3" piece fit right on it with zero problem....
  8. #8 Re: Home Depot DIY CAI not happenin!!
    Canada
    I can get the 3" parts to fit thats not a concern. What worries me is visually I can see a size difference between stock components and 3". Yikes If i can see that I can just imagine how much less air that is getting into that motor.
  9. #9 Re: Home Depot DIY CAI not happenin!!
    Jul 2008
    Tampa, FL
    i guess i can't see what you're talking about...
  10. #10 Re: Home Depot DIY CAI not happenin!!
    you do understand that the computer tells the car how much air and fuel the car needs right????/
    The 3in piping is plenty big enough for the air flow that these car can take in.
  11. #11 Re: Home Depot DIY CAI not happenin!!
    MO
    idk what you're having problems with. I made my intake just fine on the 06.
    <brandonl2000> LMAO D!!
  12. #12 Re: Home Depot DIY CAI not happenin!!
    Canada
    A 3" 45deg pvc tube off of the TB would be ok? All my other piping seems 3.5"
    Just thought to go with stock size at least.
  13. #13 Re: Home Depot DIY CAI not happenin!!
    Who uses stock sized piping?
    The man...that's who.
  14. #14 Re: Home Depot DIY CAI not happenin!!
    Just follow the write up. You'll be plenty fine with 3 inch tubing. Measure twice, cut once... Put it all together, take pics of your new intake, then take your car for a ride.
    Snorlax strikes again.
  15. #15 Re: Home Depot DIY CAI not happenin!!
    London Ont, Canada
    stick it to the man!
  16. #16 Re: Home Depot DIY CAI not happenin!!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    my first set up was 3inch. It does restrict. I was seeing over 100 less maff hz then when I switched to 4 inch. Ghetto yes....effective Yes...Everything I used came from Home depot.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  17. #17 Re: Home Depot DIY CAI not happenin!!
    GT Level Member Ravenwald's Avatar
    May 2011
    Fort Myers, FL
    My intake is a massive pile of win. No need to take out my left friggin' headlight. No need to every do anything to it again actually. However, yours was cheaper, quicker, and probably involved far less colorful language. Good on ya!
  18. #18 Re: Home Depot DIY CAI not happenin!!
    MO
    Totally different setup guys. This is an 04+
  19. #19 Re: Home Depot DIY CAI not happenin!!
    May 2011
    Fort Myers, FL
    Psh. Everyone knows the 97-03 generation is better! Represent!
    But seriously....corn.
  20. #20 Re: Home Depot DIY CAI not happenin!!
    97-03 is the best
    SMGPFC Member #10
  1. cant wait to get home
    By gtcoup in forum Off Topic Discussion
    Last Post: 03-01-2011, 01:37 PM
  2. Go Static or Go Home....
    Last Post: 03-01-2011, 08:40 AM
  3. MW2 War at Home edition
    By ZR1Vette09 in forum Off Topic Discussion
    Last Post: 11-11-2009, 12:51 AM
  4. Any Home A/c guys on here?
    By Rocket468 in forum Off Topic Discussion
    Last Post: 05-22-2009, 06:28 PM
  5. Home?
    By GTPluv in forum Off Topic Discussion
    Last Post: 03-02-2008, 07:17 AM
