Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
Threaded View
  1. #11 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Donating Users moddman's Avatar
    Midwest
    Did not see a post showing how its done(Cat Diagnostic Disabled) so this is to help the newbie out. Just zoom in on pic after you save it to your pc. Set the cat enable temp to 20 C*. Set tests per trip to zero.
    Removing rear O2 sensor on 01-newer PCMs -- Things you should know Attached Images
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
