I dont see any reason to get involved with a open/closed loop discussion.... But my suggestion is someone used to OBD1 / map sensor setups would probalby find it is much easier to run open loop on a maf sensor.
As far as the "different climates" and "some guy came in with a bad open loop tune" goes... I have never had issues with temperatures, elevation change, humidity, or anything hurting any of the 15+ cars I have put on open loop.
2 of the fieros I have done in michigan were shipped out to moutian areas, one in PA the other in colorado... both with widebands and they both know how to use them, neither have had to adjust their tunes...
Also every open loop tune I have done will command no more fuel than about 15.1 in most cases, and at cruise it usually averages a 16:1 air fuel.... If it ever gets too far off in a rich direction it will just be moving closer to what a closed loop car does normally.
Also, professional tuners like ourselfs have a few other tricks that we normally do to enhance closed loop operation with bigger cams... The laymans out there reading the stupid "tuner guide" are just going to throw a pile of crap at their maf and hope for the best.
