Glad to hear that fixed your problem! The fuse could have blown for a number of reasons but likely wasnt from a bad solenoid in the trans. One of the wires that comes off of that fuse runs to a switch on the brake pedal and then back out to the TCC solenoid to dissable power to it during braking so the engine wont stall. More often than not its a bad switch or wiring problem that would blow the fuse. If it happens again then maybe you will have something concrete to search for but intermittant problems can make you chase your tail for a long time.
