Thread: Trans problem with 96 Grand Prix - need a little help, please
Results 1 to 7 of 7
  1. #1 Re: Trans problem with 96 Grand Prix - need a little help, please
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    It likely isnt anything electrical causing your problems. The last time you drove the car everything worked perfectly normal? Have you tried letting it warm up a good while to see if anything changes? There are a number of things that could cause your problem but they are all internal. If pulling it into manual 1 doesnt help much then your problem is likely in the input clutch drum or you have a stuck valve in the valve body. Will the car pull itself at all in D-1? If it just feels like its stalling up really hard like its starting off in 3rd or 4th gear then it could be another problem.
  2. #2 Got the codes...
    May 2008
    Computer threw three codes:
    P0753 - Shift Solenoid A Circuit
    P0758 - Shift Solenoid B Circuit
    P1864 - Manufacturer Controlled Transmission
    Trannyman:
    Thanks very much for the response.
    Warmed the car up to normal operating temp. No change in behavior. In D, the car can get moving, but it feels like the torque converter is behaving like a 4000 RPM race converter that never does lock up. In 1st, it pulls a little better, but nowhere like normal. Starts in 2, 3 and D are pretty much the same. Lots of RPM and not much acceleration.
    Just for the hell of it, I tried clearing all the codes. The first two stayed off but the third code (the seemingly most vague of the three) threw again.
    No shuddering, no noises. Still pulls in reverse just fine.
    Any idea where to start?
    Thanks...Boatman
  3. #3 Re: Trans problem with 96 Grand Prix - need a little help, please
    Fort Wayne, IN
    I would check fuses first thing. If there is no power at all going to the transmission then it will take off in 3rd gear and will take off in a lower range if manually pulled into a lower range, I believe only 2nd gear and not 1st. There should be a pink wire on the harness that plugs into the front top area of the trans, this will be your 12v + wire and should have ignition voltage. If not then this is your problem.
  4. #4 Re: Trans problem with 96 Grand Prix - need a little help, please
    Fort Wayne, IN
    I just looked at the wiring schematic for your car and the fuse should be labeled TCC/Cruise 15A fuse, Underhood fuse box
  5. #5 You're good - right on the money!!!
    May 2008
    Thank you very much for the informative post. You are clearly an asset here and you got the problem right on the money. Before I saw your post, I was googling my codes and came up with a post on a Lumina board. A guy had the same problem as me and the same three error codes. Someone posted back that didn't have a trans problem, he had a blown fuse.
    Went right to my fuse box and found that the 15A minifuse, middle right was blown. Couldn't read the box cover too well but looked like it said TCC. If so, that makes a lot of sense - no power to the torque converter to lock up. Put in a 15A fuse, cleared the codes, drove it for a half hour and it's fine. Dives great and no codes.
    Seems like that was the problem. But I'm wondering - why did the fuse blow in the first place?
    Any ideas.
    Thanks...Boatman
  6. #6 Re: Trans problem with 96 Grand Prix - need a little help, please
    Fort Wayne, IN
    Glad to hear that fixed your problem! The fuse could have blown for a number of reasons but likely wasnt from a bad solenoid in the trans. One of the wires that comes off of that fuse runs to a switch on the brake pedal and then back out to the TCC solenoid to dissable power to it during braking so the engine wont stall. More often than not its a bad switch or wiring problem that would blow the fuse. If it happens again then maybe you will have something concrete to search for but intermittant problems can make you chase your tail for a long time.
  1. New Guy with '04 Grand Prix GTP
    By NSUstud in forum Introductions/Noob Questions
    Last Post: 10-01-2008, 07:44 AM
  2. Trans problem - 96 Grand Prix
    By Boatman in forum General Tech Discussion
    Last Post: 05-03-2008, 05:26 PM
  3. about the grand prix
    By Wadeb79 in forum Off Topic Discussion
    Last Post: 03-24-2008, 11:03 PM
  4. would trans am rims fit a grand prix
    By ryangtp89 in forum Tires & Wheels
    Last Post: 03-09-2008, 10:19 AM
  5. New to me Grand Prix GT 97
    By mainecrab in forum Visual/Body Modifications
    Last Post: 02-10-2008, 11:38 PM
