Been here...done this.
If you are tuning with DHP, you should be able to do it. Get a trans connector off a 4T65E, 5 pcm pins with some wire, the trans and both axles.
Do the swap, convert over the connector (there's about 7 wires on your connector that map right over) then add in the additional 5 wires to the location they'd be if your car had been supercharged. Drag and drop the trans file from a supercharged to your bin and program it up.
only thing I did differently was I did this on a 96 Riviera, therefore we just used a 97 pcm that had the 65E as a trans. But I've seen guys drag and drop most of the trans section on a DHP w/o problems.
