Thread: Transmission tuning specifically TCC lockup stuff
Results 1 to 17 of 17
  1. #1 Transmission tuning specifically TCC lockup stuff
    GTP Level Member
    Jan 2015
    Lincoln, NE
    I havent ever really tuned a transmission before yeah ive tuned the lock and unlock speeds, gearing, shift times, etc but i have never played with the forced motor current tables. my question is how do you know what and when to change it. i have both HPtuners and DHP.
    turbo car, 450 hp at the wheels, TEP tranny with most of the goodies, 3100 stall. the TC locks and unlocks fine but i have some knock during acceleration from a stop. WOT is fine no issues there just some drivability issues and im not sure where to start. the car is currently running in open loop due to the fact that i run race gas and changing O2's all the time got old. I tune the MAF, PE via Wideband O2 error %. just looking for some direction on the trans.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #2 Re: Transmission tuning specifically TCC lockup stuff
    ive got a zzp trans tune bin, and the all mighty loved by all billboost tranny tune i could send you both.
    the zzp one has almost all the tm removed and the line pressure jacked up. bills has a lot of tm left in it. and the line pressures not jacked up like the zzp settings. so you dont kill the tranny.
  3. #3 Re: Transmission tuning specifically TCC lockup stuff
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Pfullen1@gmail.com if you would send them over. i pretty well have the TM and shift settings setup the way i want to protect the clutches at the shift i jsut cant seem to get rid of this light throttle off idle cruise KR figured out and am wondering if it is related to the high stall TC.
  4. #4 Re: Transmission tuning specifically TCC lockup stuff
    well at least with the two extra files you can see the differences in each.
    we are seeing a fair amount of this cruise kr over the last few months for sure.
    ill email them in a bit, need to fire up the lap top.
  5. #5 Re: Transmission tuning specifically TCC lockup stuff
    both files i sent you are a 98 regal, the one named brian is the zzp tune.
  6. #6 Re: Transmission tuning specifically TCC lockup stuff
    GT Level Member mguzzo's Avatar
    Buffalo NY
    drop the bill tune to me also
    mguzzo66@gmail.com
    thx
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  7. #7 Re: Transmission tuning specifically TCC lockup stuff
    sent
  8. #8 Re: Transmission tuning specifically TCC lockup stuff
    Buffalo
    You guys still let it lock in 3rd too? Ditched that for a while. Also make it so you don't have to "dig in" into the pedal before it unlocks (most useful when you allow to lock in 3rd and 4th)
  9. #9 Re: Transmission tuning specifically TCC lockup stuff
    hangover park IL
    with the turbo regal I changed a lot of the downshift tables to make sure that when it up shifted it would not down shift
    the turbo loved the load
    I never really use torque converter clutch lock up except in higher speeds in 3rd otherwise it would drone, 4th really f***** with it locked up unless you were doing 75.
    but really the turbo car shift tables and settings have almost nothing in common with all of my supercharged Trans folders
    the engines want different loads at different rpms there's no way that a one-size-fits-all transfile will work
    ~James~ Psychotic Gearhead
  10. #10 Re: Transmission tuning specifically TCC lockup stuff
    hangover park IL
    I'm sure I'm going to need more adjustments than just the shiftable adjustments going to the new 2.93 final drive chain set with the new converter stall
  11. #11 Re: Transmission tuning specifically TCC lockup stuff
    Scott.. just put the link to the dropbox in the thread. Quicker and easier
  12. #12 Re: Transmission tuning specifically TCC lockup stuff
    its no wheres near fast if you dont know what bin to take it from. and im not into typing out directions to it. i know its in my bin, so thatrs easy.
  13. #13 Re: Transmission tuning specifically TCC lockup stuff
    Slacker, I told you 2000 Regal under my name and which one. You were the one that got lost with a GPS in hand.
  14. #14 Re: Transmission tuning specifically TCC lockup stuff
    it just easier to send someone what they want really, dont ya think?
    theres a bunch of bins under your name.
  15. #15 Re: Transmission tuning specifically TCC lockup stuff
    I always felt the more stuff I had to reference and review, the better.
  16. #16 Re: Transmission tuning specifically TCC lockup stuff
    but what if you not on the phone with the guy who put it all together so he can tell you exactly what bin to use?
    remember, you said theres one to use, and one not use or boom goes the tranny.
    why i just sent them one of my bins with it in there, no guessing for any one.
  17. #17 Re: Transmission tuning specifically TCC lockup stuff
    No, I said..one was the latest and one was the SC vs NA
  1. Tuning for a manual transmission
    By Jeckel in forum PCM Tuning
    Last Post: 02-19-2014, 09:17 AM
  2. Transmission tuning?
    By Reverant GTP in forum PCM Tuning
    Last Post: 03-05-2013, 02:07 AM
  3. Need some Grand Prix input....transmission stuff
    By Aklilu Kassa in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-16-2011, 10:02 AM
  4. Valve springs (L76 specifically)
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 01:13 PM
