Thread: Tuning for a manual transmission
Results 1 to 4 of 4
  1. #1 Tuning for a manual transmission
    SE Level Member Jeckel's Avatar
    Feb 2010
    Nampa, ID
    I have a buddy that recently put a 3800 into his fiero. Using DHP, that tables do I need to change so he can shift above 4K?
    He is using a 2002 pcm and bin file.
  2. #2 Re: Tuning for a manual transmission
    Feb 2009
    flintnasty MI
    if he didnt hook any shift logic up, he should be in "D" all the time according to the PCM.
    For the most part I dont change anything other than DTC codes for manual swaps. The motor runs alot different due to the different gear ratios so I bounce timing up alot, enable really lean cruise, etc.
  3. #3 Re: Tuning for a manual transmission
    Florida
    if it wont go above 4k then the pcm thinks the car is in neutral. like DH said adjust so that it thinks its in drive, or adjust the tables so the rev limiter is higher in neutral... but not sure if other tables are adjusted if the car thinks its in N. I suggest adjusting the harness so that the Neutral safety switch is properly connected to the pcm so that it sees if the car is in N or D(a gear)
  4. #4 Re: Tuning for a manual transmission
    Mar 2012
    NC
    I used TinyTuner to change the trans to manual then adjusted gear ratio and pulse per mile in my GP. Worked like a charm.
  1. WTB: Jackshaft for Manual Transmission
    By Blacktree in forum Wanted To Buy - Parts
    Last Post: 01-15-2014, 11:34 PM
  2. Transmission tuning?
    By Reverant GTP in forum PCM Tuning
    Last Post: 03-05-2013, 02:07 AM
  3. AWD Car with Manual Transmission (NO JAP CRAP)
    By winterstorm in forum Off Topic Discussion
    Last Post: 01-08-2013, 10:45 AM
  4. manual transmission for a 95??
    By Drifty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 06-28-2010, 01:23 PM
  5. Looking for a 4 door manual transmission car
    By Deezul_AwT in forum Off Topic Discussion
    Last Post: 12-28-2008, 11:05 PM
