Thread: Anyone ever figure out how to unbrick a PCM?
Results 1 to 20 of 29
  1. #1 Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Seems my downfall was opening the car door while uploading a .bin with DHP. Next time I'll just stay in the car for the estimated 2 hour write time...
    7"
  2. #2 Re: Anyone ever figure out how to unbrick a PCM?
    Try to write it again??
    Otherwise it's ****ed.
  3. #3 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Yeah any attempt to read or write to it fails. Good thing it was the spare PCM I bought.
    7"
  4. #4 Re: Anyone ever figure out how to unbrick a PCM?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Any time I get an error while writing, I never turn the key to off, I go back and restart a full write, has worked every time so far (only 2-3 times total since I've had my PT). Once you turn that key to off, I think you're pretty much fked.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  5. #5 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Yeah it warned me not to turn the key off, but after an hour of trying to recover and failing the same way each time, I had to try something new.
    7"
  6. #6 Re: Anyone ever figure out how to unbrick a PCM?
    i bricked mine when the laptop crashed during a write. i tossed it in the corner of the garage and then 6 months later with a off board i got it to take a bin again.
    i just kept playing with the vin # and auto recovery, forced recovery options and it finally took.
  7. #7 Re: Anyone ever figure out how to unbrick a PCM?
    May 2012
    Where winter never ends
    Lots of time HPT can do a recovery. Depending on the state it may need custom software to get it back or even a new EEPROM, its hard to know without know exactly where it failed in the process.
    Sent from my VS986 using Tapatalk
    2000 Regal - Winter Beater
  8. #8 Re: Anyone ever figure out how to unbrick a PCM?
    Bastard Reptile's Avatar
    Kansas City, MO
    I've had it fail on the VIN verification several times, give up on it....close the program and then try again with success. Pretty much what Decker said, it depends on where it's at in the writing. BUT....if you lose power or connection while it's in the process it's usually a gonner.
  9. #9 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Alright then it's probably toast. The error I get is that it "Can't retrieve module 0A". It failed at about 8 percent into the write process which apparently was when I got out of the car. I had a battery tender hooked up so I wouldn't drop voltage but I didn't pull the radio fuse.
    7"
  10. #10 Re: Anyone ever figure out how to unbrick a PCM?
    best thing to do is always have a spare. mines in my trunk. this reminds me, i need to flash this top swap tune to it now lol
  11. #11 Re: Anyone ever figure out how to unbrick a PCM?
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    We need Dark to come in and say that he's never had a write fail lol
    Email all inquiries to willoverkill@gmail.com!
  12. #12 Re: Anyone ever figure out how to unbrick a PCM?
    Quote Originally Posted by Overkill View Post
    iirc he did say he can un brick them tho.
  13. #13 Re: Anyone ever figure out how to unbrick a PCM?
    May 2012
    Send it to me. I wanna pull the EEPROM and see what happened exactly. Lol
  14. #14 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Quote Originally Posted by ADecker View Post
    I could do that. But I just bought 2 more off eBay to play with so if you wait maybe I'll have 3 bricks to send lol.
  15. #15 Re: Anyone ever figure out how to unbrick a PCM?
    May 2012
    Awesome! :P I want bricked stuff...see what went wrong maybe fix it
  16. #16 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Aaaand brick #2
    4 ****ing hours sitting in the car this morning, furthest I got was %40. Eventually after probably 30-40 failed restarts the PCM just stopped communicating.
    Gonna have to say it's looking like my 2005 is not one of the ones that can use DHP :/
    7"
  17. #17 Re: Anyone ever figure out how to unbrick a PCM?
    are you pulling the radio fuse while reading or writing?
    and always try to read a pcm first its less of a fail if it quits reading, if it crashed writing its over unless you dont turn the key off some say.
  18. #18 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    Pulled the bins from all three PCMs before attempting any writes, so that works, takes 10-15 minutes but didn't fail once. I don't have the option to do a partial write, and a full write takes between 120-240 minutes depending on block size selected.
    Pulled the radio fuse. Never turned the key off at all this morning, was connected to the battery tender but DHP says my system voltage was at 0v.
    Doesn't fail at the same spot ever. Sometimes it would write for 1-5-10 minutes and fail, attempt auto recovery, write a few minutes and fail again, sometimes write for an hour straight before failing.
    7"
  19. #19 Re: Anyone ever figure out how to unbrick a PCM?
    get a newer dhp version. my dhp box is old as dirt and i have the partial write option and the clear fuel trims box.
    and your reading and flashing is taking to long. im on slow speed and do a full write in 776 seconds. about 10 minutes iirc.
    my block size is set to 1024. thats its default setting i guess and works fine for me, ive never changed it.
    im using powertuner v1.2.4
  20. #20 Re: Anyone ever figure out how to unbrick a PCM?
    Oct 2011
    Toledo, OH
    I've got 1.2.4, hardware version 13. It's not DHP issue per se. 2005 isn't officially supported, you can only do full write on them so I knew there was a chance it wouldn't work right.
  1. cant figure it out
    By gwizz69 in forum General Tech Discussion
    Last Post: 10-19-2011, 05:43 AM
  2. Can't figure this out...
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2011, 04:43 PM
  3. Trying to figure out what I can do
    By garreTT in forum Audio, Security & Visual Electronics
    Last Post: 09-03-2010, 10:53 AM
  4. trying to figure out...
    By CMURDAx in forum Off Topic Discussion
    Last Post: 05-30-2010, 10:40 PM
  5. Cant figure this out
    By GTPJAY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 05:11 PM
