Thread: maf tuning help please
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 83
  1. #1 maf tuning help please
    Dec 2013
    laporte mn
    i just installed sd headers, yella terra 1.84 full roller rockers, and a LQ4 maf with a 4" fenderwell intake on my 04 comp g. I still have the stock 3.8" pulley. I imported the lq4 maf table from zzp and went to scan. the cruise scan has no kr.
    the question I have is with the WOT scan. im seeing kr and my wideband is at 13.5 the entire pull, im just wondering how I go about richening it up? any help would be awesome
    I don't yet know how to attach tune files or scans. so I can email them to u f u want to see them, or if someone can tell me how to do that as well it would be appreciated.
    sorry im new to the tuning scene, but I work as a mechanic daily so I know the just of what everything does. not my first modified car just my first tuning experience
  2. #2 Re: maf tuning help please
    use eddie's table modifier. its pretty much dummy proof. you dont really need to "know" how to tune with it.
  3. #3 Re: maf tuning help please
    Kemmerer, Wyoming
    I would find out if you really need that LQ4 maf, and if not put the stock one back on. are you using dhp or hp tuner?
  4. #4 Re: maf tuning help please
    Why did you upgrade maf sensors??
    Are you going to outflow the stock maf sensor??
    Most people on 3.25's to 3.4 can't outflow the maf anyway.
    And you add to the MAF table to increase fuel. You add by %, so from where you need more fuel, figure from 7,000hz you could add 3% more to the table.
  5. #5 Re: maf tuning help please
    Dec 2013
    laporte mn
    Scottydoggs do u have a link to Eddie table modifier.
    Sgt marshal I'm using dhp
    Fivefingerdeathpunch I upgraded because it fit nicely into my 4" intake. I didn't want the bottle neck and I will need it eventually so I would like to get used to it
  6. #6 Re: maf tuning help please
    Kemmerer, Wyoming
    download this application, read the directions on how to use it, it will do maf and ve tuning, as well as add timing. it is a really good tool.
    http://theblattners.com/projects/tab...r/Default.html
    and here is a link to a uv scan software application. you can use it to take scans, it is much better than the dhp scanner. hopefully the link will work
    https://www.dropbox.com/s/g884dg0a6e...canII.zip?dl=0
  7. #7 Re: maf tuning help please
    pm'ed
  8. #8 Re: maf tuning help please
    Dec 2013
    laporte mn
    I already have uvscan 3, or something like that but it always says I have too many pids to scan
  9. #9 Re: maf tuning help please
    Kemmerer, Wyoming
    you are probably trying to scan too many things, have you tried unchecking some of the pids?
  10. #10 Re: maf tuning help please
    Dec 2013
    laporte mn
    I will try that.
  11. #11 Re: maf tuning help please
    Quote Originally Posted by gambler87 View Post
    Far enough, but in reality the throttle body is always going to be smaller than your intake size and you can never upgrade your throttle body.
  12. #12 Re: maf tuning help please
    Dec 2013
    laporte mn
    I'm not going to say never seeing that u can get up to 100mm drive by wire throttle bodies. Just have to make an adapter plate. Not that I would but I don't say never
  13. #13 Re: maf tuning help please
    The stock pcm for a 3800 can't be tuned for the upgrade though, they don't provide enough data/tables to allow for a change. A GM V8 pcm is far more advanced and has 10x the tables to allow for adjustment of throttle blade size.
    Sorry to bring this off topic more, but thats the truth of it.
  14. #14 Re: maf tuning help please
    Dec 2013
    laporte mn
    OK, so i imported my scan and my maf table into the table modifier and then I don't know what to do with it
  15. #15 Re: maf tuning help please
    Dec 2013
    laporte mn
    This is the message I get when I try and import it into my dhp tune file.
  16. #16 Re: maf tuning help please
    Dec 2013
    laporte mn
    This is the message I get when I try and save the new maf table
  17. #17 Re: maf tuning help please
    Kemmerer, Wyoming
    did you read all the directions on the blattners website on what to scan for, and how to import tables?
  18. #18 Re: maf tuning help please
    Apr 2015
    Columbus, OH
    That's odd. I get the same message, but only when I try to import the VE table. You can look at the .CSV file and see what rows are not in it. In my VE export from TM the first two rows are not there. That's why dhp won't import the file.
    Top Swapped 01 Imp
  19. #19 Re: maf tuning help please
    Dec 2013
    laporte mn
    I click on the CSV file and no data shows up just a whole bunch of empty cells. I import my bin file to table modifier so it automatically imports my new tables into my bin file and saves them. I'm trying it that way right now
  20. #20 Re: maf tuning help please
    Dec 2013
    laporte mn
    I read the entire guide on blattners.
  1. 3.29 to 2.93 Tuning
    By wa04compg in forum PCM Tuning
    Last Post: 06-27-2013, 10:23 PM
  2. Tuning help in NYC
    By buickman104 in forum PCM Tuning
    Last Post: 10-11-2012, 08:02 PM
  3. PCM Tuning
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 10-11-2012, 08:13 AM
  4. Tuning Amp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 09:30 PM
