Thread: Interpreting scan logs, any help please?
Results 1 to 20 of 80
  1. #1 Re: Interpreting scan logs, any help please?
    you try using uvscan with the wideband? then use that scan in eddies.
    you going through the egr wires to read the wide band? i need to set that up. something with a pid needs to be added or something?
  2. #2 Re: Interpreting scan logs, any help please?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by ScottyBDoggs View Post
    Yes, using UVscan with Wideband through egr. But in TM I don't see any options to change anything for wideband. When you export a MAF or VE tune in TM, you have the options popup, and the wideband tab is greyed out. Can't select anything. There is an options that says "check this box if you are tuning using a wideband o2 sensor" but you can't tick it. I'm using TM 6.9
    Top Swapped 01 Imp
  1. PRJ Fuel logs
    By Javi in forum Wanted To Buy - Parts
    Last Post: 02-05-2015, 11:38 AM
  2. Fuel Logs, 42.5's
    By Dtrick22 in forum Wanted To Buy - Parts
    Last Post: 02-28-2014, 01:18 PM
  3. Interpreting torque specs.
    By NinetyEightGTP in forum General Grand Prix Discussion
    Last Post: 07-04-2013, 10:05 PM
  4. WTB: Fuel Logs
    By 1999black3800 in forum Wanted To Buy - Parts
    Last Post: 03-16-2013, 09:49 AM
