Thread: How do I keep killing my hp tuners interface
Results 1 to 9 of 9
  1. #1 How do I keep killing my hp tuners interface
    SE Level Member 04whitegtp's Avatar
    May 2014
    Lansing Michigan
    About a month ago i received the "unable to locate interface" error. Went through with support and got my new interface in the mail the other day. after i read the ecm i liscenced it and all that, got everything working. When I got home from a drive, saved my scan. Went to change some things with the editor and when I went to flash i got the same error. But now i its not getting power from the obd2. There is 12v at obd2 connection. I'm not sure where to do
    Using Tapatalk
  2. #2 Re: How do I keep killing my hp tuners interface
    Weird, I've never got that error before.
    Have you tried re-installed all the software just incase???
    And you arent ever running a battery charger on the laptop when you have the MPVI plugged in right? Because that can ruin them.
  3. #3 Re: How do I keep killing my hp tuners interface
    May 2014
    Lansing Michigan
    Yes, ive re installed Windows. And never had it plugged in.
    Using Tapatalk
  4. #4 Re: How do I keep killing my hp tuners interface
    I'd just assume you've tried all the other USB ports on the computer too.
    Maybe a cable issue??
  5. #5 Re: How do I keep killing my hp tuners interface
    Buffalo
    What are you using to power your laptop while using the interface in the car?
  6. #6 Re: How do I keep killing my hp tuners interface
    May 2014
    Lansing Michigan
    The laptop battery. I never had it plugged in to the car
    Using Tapatalk
  7. #7 Re: How do I keep killing my hp tuners interface
    When I had one go, Chris and Bill mentioned that plugging it in like the others mentioned is usually the culprit based on grounding or lack of.
    What type of laptop are you using?
  8. #8 Re: How do I keep killing my hp tuners interface
    Buffalo
    Power invertors seem to cause this issue
  9. #9 Re: How do I keep killing my hp tuners interface
    May 2014
    Lansing Michigan
    I have a dell precision m6400.
    Using Tapatalk
  1. UPS - Killing our sh!t
    By deadwoodspecial in forum The Rant Forum
    Last Post: 12-28-2013, 08:33 AM
  2. Keeps killing batteries
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2013, 12:37 PM
  3. The Killing
    By Sudden in forum Off Topic Discussion
    Last Post: 06-20-2012, 07:28 PM
  4. killing spree
    By chad27 in forum Track Sessions and Kills
    Last Post: 05-07-2009, 06:42 AM
  5. killing KR
    By Smokedgtp in forum Turbo
    Last Post: 05-10-2008, 05:35 PM
