Thread: 04 up off board help.
Results 1 to 20 of 32
  1. #1 04 up off board help.
    im looking for a little help on a 04 up off board.
    i need the pin #'s pcm plug to obd2 port. im using the one plug, found the one data serial line # 15. but cant seem to find the other data pin.
    thanks.
  2. #2 Re: 04 up off board help.
    Feb 2013
    Missouri
    I saw TurboSBC or whatever his name is had info on one, I PM'd him but never got a reply so maybe he'll chime in on it.
  3. #3 Re: 04 up off board help.
    i tried to pm him, his box is full........so its post time.
  4. #4 Re: 04 up off board help.
    Feb 2013
    Missouri
    Bill will probably chime in, he sold some back in November.
  5. #5 Re: 04 up off board help.
    Aug 2011
    colorado
    I've got one another member built for me. if nothing else i can snap a pic and send it to ya if that would help you
  6. #6 Re: 04 up off board help.
    id need to see the pin #'s on the pcm plug. to sse that the black plastic cover needs to be taken off.
  7. #7 Re: 04 up off board help.
    Feb 2013
    Missouri
    I can try and get those for ya Scotty, lemme fire up Alldata...
  8. #8 Re: 04 up off board help.
    i found a post with the pin outs. im only seeing pin 15 as a serial data, im not seeing the other one on the same plug.
  9. #9 Re: 04 up off board help.
    Feb 2013
    Missouri
    Alldata was a no go, just schematics. I found these pics in another thread though:
    Original post:
    http://www.grandprixforums.net/threa...l=1#post562679
    Damn it. you found it the same time I did, lol.
  10. #10 Re: 04 up off board help.
    i need the serial data (uart) pin # it looks to be on the next plug.
  11. #11 Re: 04 up off board help.
    Feb 2013
    Missouri
    C2 pins 2 &3?
  12. #12 Re: 04 up off board help.
    thats the one, but i know for a fact people have made them with only the one plug.
  13. #13 Re: 04 up off board help.
    Feb 2013
    Missouri
    It's gotta be that pin 15 then, you don't have a PCM laying around do you?
  14. #14 Re: 04 up off board help.
    thats the thing, i dont have a 04 pcm. 15 gets used, then you need the other two pins as well. as per a 07-03 off board, aka going for the same wires.
  15. #15 Re: 04 up off board help.
    Feb 2013
    Missouri
    Hmpf. I wish someone that has built one would chime in. I know the ones Bill sold were 2 plugs. You talking about that one TurboSBC made with the metal plate and diodes?
  16. #16 Re: 04 up off board help.
    i just need to know what pins to use off the one plug lol im not using diodes and crap. all i know is its been done with one plug.
  17. #17 Re: 04 up off board help.
    Feb 2013
    Missouri
    I know, you know what I mean though.
  18. #18 Re: 04 up off board help.
    Pin 15 on C1. Give that same connector power to the IGN wires and then use one of the low references as a ground. Otherwise use the mother of all grounds on C2.
  19. #19 Re: 04 up off board help.
    ive got pin 8 for ground, 15 for class data, 18 and 19 for ignition power.
    if i power 15 wheres the data gonna cross over from?
  20. #20 Re: 04 up off board help.
    Christ.. youre effing killin me.
    Data pin 15
    Power anything labeled ign
    ground.. any of the lows
  1. Replies: 0
    Last Post: 05-28-2013, 12:21 PM
  2. On Board Air
    By DirtDog in forum Off Topic Discussion
    Last Post: 04-29-2013, 01:01 PM
  3. New To The Board
    By TwinCharged01 in forum Introductions/Noob Questions
    Last Post: 01-31-2012, 03:03 PM
  4. 207 is up on the board....
    By 100 BUX in forum Northeast
    Last Post: 01-04-2010, 09:48 AM
  5. New to the Board
    By Gibbster in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 10:55 AM
