Having some weird issues with DHP 1.2.4. I am unable to do any partial tunes. It usually fails on the reset and ill have to try to write again a few times for it to complete connection. When this happens most of the gauges and service lights flash through then leaving a blank cluster with only lights. Anyways Ive successfully written a bin about 4-5 times.
I made a long scan and imported it into the table modifier along with the bin's maf table. I then exported it with the basic settings, imported into bin and the wrote the bin to the car. When I looked through the old maf table compared to the modified table there was very little to no change. Some values only changed .0X and the rest none at all. There were also some that had a bit more of a change.
I am unable to get powerscanner to work at all it just gives me an error in either starting or when loading the pids. UVScanner2 has worked for me with scanning but when I goto PCM Tools and click on LFTF-reset nothing happens at all.
|Any other tips to help me tweak?
