I can't get TT to work in windows 7. I run DHP PT fine.
I understand it was made a long time ago, but thought it runs on the same NET frameworks as DHP..
Thanks
Thanks
Runs on windows 8 in xp compatability mode, should be able to do something similar in win 7.
Right click on tinytuner and troubleshoot compatability. Should be able to select xp mode.
you also need to download the osid and the pid list. then open up tt and select the database.
options> select database. then a window opens to find where you saved it to.
i downloaded the bottom 3 links found at the bottom of this page. http://theblattners.com/Projects/TinyTuner/default.html
Ok, TT does open up.
I DL'd the database. I go to open in TT, but nothing happens.
Yeah, I did that
I click on active TTDB 09 28 13 go to open. Nothing happens. Do I need to load a BIN first?
sorry. Im not a newb to this stuff but it's been a very long time since I fooled with PT and TT and all that stuff.
Well, got it too work.
For some reason the shortcut I was using for tiny tuner was bad. I went to the program files and opened it there it worked fine.
Now what is the purpose of the database once the BIN is loaded?
