Thread: Tiny Tuner in Windows 7
Results 1 to 13 of 13
  1. #1 Tiny Tuner in Windows 7
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    I can't get TT to work in windows 7. I run DHP PT fine.
    I understand it was made a long time ago, but thought it runs on the same NET frameworks as DHP..
    Thanks
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  2. #2 Re: Tiny Tuner in Windows 7
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Runs on windows 8 in xp compatability mode, should be able to do something similar in win 7.
    Right click on tinytuner and troubleshoot compatability. Should be able to select xp mode.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  3. #3 Re: Tiny Tuner in Windows 7
    you also need to download the osid and the pid list. then open up tt and select the database.
    options> select database. then a window opens to find where you saved it to.
    i downloaded the bottom 3 links found at the bottom of this page. http://theblattners.com/Projects/TinyTuner/default.html
  4. #4 Re: Tiny Tuner in Windows 7
    Kemmerer, Wyoming
    if the program opens but doesn't work, you probably need to select the database and/or download it.
  5. #5 Re: Tiny Tuner in Windows 7
    Houston/Baton Rouge
    Ok, TT does open up.
    I DL'd the database. I go to open in TT, but nothing happens.
  6. #6 Re: Tiny Tuner in Windows 7
    you need to tell tt where the file is,
  7. #7 Re: Tiny Tuner in Windows 7
    Houston/Baton Rouge
    Yeah, I did that
    I click on active TTDB 09 28 13 go to open. Nothing happens. Do I need to load a BIN first?
  8. #8 Re: Tiny Tuner in Windows 7
    Houston/Baton Rouge
    sorry. Im not a newb to this stuff but it's been a very long time since I fooled with PT and TT and all that stuff.
  9. #9 Re: Tiny Tuner in Windows 7
    yeah you need to open a bin, or its got nothing to work with.
    file, open binary file.
    also in options check "use data base when available."
  10. #10 Re: Tiny Tuner in Windows 7
    Houston/Baton Rouge
    Ok, thanks man. Let me try that
  11. #11 Re: Tiny Tuner in Windows 7
    Houston/Baton Rouge
    Well, got it too work.
    For some reason the shortcut I was using for tiny tuner was bad. I went to the program files and opened it there it worked fine.
    Now what is the purpose of the database once the BIN is loaded?
  12. #12 Re: Tiny Tuner in Windows 7
    Kemmerer, Wyoming
    if I understand it right, the database provides definitions for all the different tables.
  13. #13 Re: Tiny Tuner in Windows 7
    all i know is it wont open a bin till you find the database where you stored it and use it.
  1. HP Tuners and Tiny Tuner
    By LapeerGTP in forum PCM Tuning
    Last Post: 12-04-2015, 09:44 PM
  2. Tiny Tuner
    By NebTurboST5 in forum PCM Tuning
    Last Post: 01-08-2015, 06:45 AM
  3. tiny tuner won't open bin
    By dsmuts in forum PCM Tuning
    Last Post: 04-26-2013, 07:30 PM
  4. Tiny Tuner help
    By Bedwards in forum PCM Tuning
    Last Post: 08-19-2011, 01:28 PM
  5. PT vs Tiny Tuner; Spark mg/cyl not the same...?
    By agrazela in forum PCM Tuning
    Last Post: 03-07-2009, 05:20 PM
