Thread: tiny tuner won't open bin
Results 1 to 12 of 12
  1. #1 tiny tuner won't open bin
    I get an error message and wondered if anyone knew how to get it to open for me.
    Unhandled exception has ocurred in your application. If you click
    Continue, the application will ignore this error and attempt to continue.
    If you click Quit, the application will close immediately.
    Could not load file or assembly 'TinyTunerDLL, Version=1.0.0.0,
    Culture=neutral, PublicKey Token=null' or one of its dependencies.
    The system cannot find the file specified.
    Thanks
  2. #2 Re: tiny tuner won't open bin
    May 2008
    Schuyler, NE
    Can you open the file with the powrtuner software?
  3. #3 Re: tiny tuner won't open bin
    Feb 2009
    flintnasty MI
    might want to give some info, what osid would work for starters.
  4. #4 Re: tiny tuner won't open bin
    Yeah it opens fine with the powrtuner. I have made changes to it and everything but tiny tuner doesn't like it i guess.
  5. #5 Re: tiny tuner won't open bin
    Feb 2009
    flintnasty MI
  6. #6 Re: tiny tuner won't open bin
    Not sure what you mean
  7. #7 Re: tiny tuner won't open bin
    Feb 2009
    flintnasty MI
  8. #8 Re: tiny tuner won't open bin
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I dont think he understands what you mean by "Osid"
  9. #9 Re: tiny tuner won't open bin
    Feb 2009
    flintnasty MI
  10. #10 Re: tiny tuner won't open bin
    Jan 1970
    Maquoketa, Iowa
    Year-
    Make-
    Model-
    OSID-
    Version of tiny tuner-
    Database loaded on tiny tuner (bottom right flashes red IIRC)?
    Operating system of PC-
  11. #11 Re: tiny tuner won't open bin
    Florida
    the OSID is basically the software version of the bin file.
  12. #12 Re: tiny tuner won't open bin
    04 comp g
    osid 12584056
    Using windows 7
  1. HP Tuners and Tiny Tuner
    By LapeerGTP in forum PCM Tuning
    Last Post: 12-04-2015, 09:44 PM
  2. adjusting dwell in tiny tuner... anyone done this?
    By Z34Phoenix in forum PCM Tuning
    Last Post: 06-21-2012, 02:26 PM
  3. Tiny Tuner Public Release
    By FoSHO99 in forum PCM Tuning
    Last Post: 03-31-2012, 11:18 AM
  4. Tiny Tuner help
    By Bedwards in forum PCM Tuning
    Last Post: 08-19-2011, 01:28 PM
  5. PT vs Tiny Tuner; Spark mg/cyl not the same...?
    By agrazela in forum PCM Tuning
    Last Post: 03-07-2009, 05:20 PM
