I have another question: I have 42.5 lb injectors and after reading through Jerry's tuning guide decided to do the math to figure out if the scaling had been done correctly. I checked the stock IFR and then multiplied by .847, and I found my injectors had not been scaled correctly, then I drove around for a couple hours to relearn the trims. when scaling the injectors is this the only variable I need to account for, meaning multiplying by .847? To continue, do I also need to resmooth my maf curve after adjusting the trims? My other question is: when coasting down a hill is a lean condition common? for example, values of 15 or 16 happen a lot in my ltft's. this may seem like a common sense question, and I understand why it leans out, but I also understand that lean conditions are not good.
