Thread: resetting the fuel logs
Results 1 to 20 of 33
  1. #1 resetting the fuel logs
    Kemmerer, Wyoming
    I'm working on smoothing my maf table. I made some adjustments and reset the fuel trims. I havent driven the car enough to fully relearn the fuel trims, is it ok to make more adjustments based off the scan taken while the car was still relearning the fuel trims?
  2. #2 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
  3. #3 Re: resetting the fuel logs
    Kemmerer, Wyoming
    busted, you got me
  4. #4 Re: resetting the fuel logs
    Kemmerer, Wyoming
    what's the point in resetting the fuel trims and then relearning them if you are just going to reset them again?
  5. #5 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
    The reason to reset them, is it will take less time for them to relearn after you change your fueling.
    Think of it like the DIC on your car that measures MPG. You will see your most accurate MPG reading by hitting the reset button, vs. waiting for the average to catch up to your current driving style.
  6. #6 Re: resetting the fuel logs
    Arizona
    That makes no sense. Time should remain the same error is what should go down.
  7. #7 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
    Quote Originally Posted by 91parkave View Post
    Not the case for ltft's
  8. #8 Re: resetting the fuel logs
    Kemmerer, Wyoming
    I think I understand. every adjustment makes a change and by letting it fully relearn every change it will make less adjustments on the next duration.
  9. #9 Re: resetting the fuel logs
    Arizona
    Stft drive what your ltfts will be. Unless the process has changed please provide some info
  10. #10 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
    Yes. But ltft's take longer to "learn" than stft's.
  11. #11 Re: resetting the fuel logs
    GTP Level Member
    Jan 2015
    Lincoln, NE
    stft's drive the ltft's. so if you have 20,000 counts of stft's driving the ltft's and you change the maf table but dont reset the fuel trims you still have those old 20,000 counts driving the ltft's if you then only have 4,000 counts of ltft's on the new maf table you still have all that old data skewing your ltft's. over a long enough period of time it wont matter but most of us dont have weeks to **** around between tuning iterations. its not hard just reset them and move on.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  12. #12 Re: resetting the fuel logs
    Kemmerer, Wyoming
    Quote Originally Posted by NebTurboST5 View Post
    I just wanted to understand the reasoning behind always resetting the trims, this explains it pretty good.
  13. #13 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
    That's a good explanation.
  14. #14 Re: resetting the fuel logs
    Arizona
    Nobody said to not reset trims the point i made was that after reset it still takes the same time to get a new ltft value after you make changes regardless of error%
  15. #15 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
    No, it takes less time after a reset.
  16. #16 Re: resetting the fuel logs
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by GTPpower View Post
    i think what he is trying to say is that regardless if your end error is going to be -5 or -15; LTFT is going to take the same time to relearn after a reset. which doesnt even come close to answering the original question
  17. #17 Re: resetting the fuel logs
    GTP Level Member
    Jan 2015
    Lincoln, NE
    that is somewhat true, however, its not even close to an answer that would make sense for answering the OP's original question.
    OP: why do you reset trims?
    you: you should reset them because no matter how far off your error% will be after your changes, it's going to take the same amount of time for them to relearn...
    you see how that doesn't address the actual question but instead makes a statement with some validity but just confuses people...hell i was even confused as to what you were trying to say and i've been tuning for 8+ years.
  18. #18 Re: resetting the fuel logs
    Arizona
    Before u call me out use your brain to understand the chronological format of responses on a forum. My reply was to gtppowers comment.
  19. #19 Re: resetting the fuel logs
    GTP Level Member
    Jan 2015
    Lincoln, NE
    well in that case...your statement is 100% incorrect in regards to how long it will take for the fuel trims to learn. that or you cant understand GTPpowers metaphor
  20. #20 Re: resetting the fuel logs
    May 2008
    Schuyler, NE
    He likes to argue with me for some reason. That's the only thing I can think of.
  1. PRJ - Fuel Logs!
    By coolone in forum Wanted To Buy - Parts
    Last Post: 07-09-2016, 08:09 AM
  2. PRJ Fuel logs
    By Javi in forum Wanted To Buy - Parts
    Last Post: 02-05-2015, 11:38 AM
  3. Modded fuel rail leaking( should i get fuel logs??? )
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2014, 05:38 AM
  4. WTB: Fuel Logs
    By 1999black3800 in forum Wanted To Buy - Parts
    Last Post: 03-16-2013, 09:49 AM
